hp 650 laptop does not run on battery
  • ut-norm
    • Nov 2019
    • 70
    • italia
    Hello everyone. I have a problem with a HP 650 laptop that does not work with the battery. This inserted is recognized by the PC but despite being fully charged (it was charged with a similar laptop) the PC does not turn on, while it turns on regularly with the original power supply. When I unplug the power supply everything turns off. Yet the charge icon shows 100%. I have updated the bios to the latest f39 version. I do not know what to do. I have found a diagram on this forum. : p / n 010170100-600-g but not really of this card. The U0901 QZ8681LN charging chip on the schematic is present on the motherboard. I would like to understand how the battery is activated. Can anyone help me?
    Thanks for the reply
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: hp laptop does not run on battery
    https://www.badcaps.net/forum/showthread.php?t=90356
    First thing is to try another battery. Then try another battery. Finally try another battery. 99% of battery problems are the battery itself, even "new", market is filled with garbage batteries. A "new" battery should come charged at around 50%, at worst between 20% and 80%, and the machine should turn on from it. Some batteries need to be "kickstarted" by plugging in the AC adapter for a short while to turn them on.
      • 21948
      With no power attached check Q0904 S/G/D
      • ut-norm
        • Nov 2019
        • 70
        • italia
        Ok thanks The first thing I did after having found the schematic is the replacement of the mosfet q0904 -4435- (which was good) with a 4423 which has the same characteristics, without obtaining any results.
        The battery I inserted is brand new HP -mu06-100% charged with another same notebook. Unfortunately it is not possible (for me) to measure the voltage across it.
          • 21948
          Test D1004
          • ut-norm
            • Nov 2019
            • 70
            • italia
            On the motherboard there is no d1004 nor the tps51123 chip.
            51225 is present
              • 21948
              Oz8681ln
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Look carefully for some rusted or shorted cap on battery output track. Does the battery voltage reaches mb??What is the voltage readings on Q0904 with only battery attached??
                • ut-norm
                  • Nov 2019
                  • 70
                  • italia
                  On the contacts of the battery, which is fully charged, I do not detect any voltage. Connected to the motherboard I do not detect any voltage
                  .The battery was recharged with a similar laptop and runs smoothly.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Check the resistance on battery + pin. Another method to try- put black probe on battery + terminal and red probe on battery - terminal and check readings(in diode mode). reverse the polarity and check again and note the readings.
                    • ut-norm
                      • Nov 2019
                      • 70
                      • italia
                      Re: hp 650 laptop does not run on battery
                      With the tester in diode mode and with the positive probe on the negative terminal of the battery I detect 2.7 volts, with the probe on the positive 0 volts
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Something is shorted for sure. You need to check each and every component on battery discharge circuit. Do you have Lab PSU??
                        • ut-norm
                          • Nov 2019
                          • 70
                          • italia
                          Unfortunately, I don't have the original laptop schematic ...
                          I just have to check every single component of the psu ...
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            But, Do you have lab PSU??
                            • ut-norm
                              • Nov 2019
                              • 70
                              • italia
                              Yes, what should I do?
                              • Antonynl
                                • Apr 2021
                                • 74
                                • Nederland
                                Have you resolved this problem? I have a similar problem on a 450 g6.
                                • serious_electron
                                  Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                  by serious_electron
                                  Hello Everyone!
                                  I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                  06-28-2025, 02:57 PM
                                • ahmarzo
                                  Acer TMX314-51 laptop battery problem
                                  by ahmarzo
                                  I have acer laptop tmx314-51 with part no 6050A3020501.
                                  The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                  But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                  I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                  The schematic is not available...
                                  04-11-2025, 09:14 AM
                                  ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                  Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                  The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                  for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                  Narrow VDC applications where the system power source is
                                  either the battery pack or the regulated output of the charger.
                                  This makes the max voltage to the system equal to the max
                                  battery voltage instead of the max adapter voltage. Operating
                                  at lower system voltage can improve...
                                  11-05-2024, 04:43 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • doboka98
                                  Satellite C55-A-142 Laptop boots only without battery
                                  by doboka98
                                  Hello! I am fixing a Toshiba Satellite C55-A-142 (model no PSCG8E).
                                  It came with an old battery. Laptop was rebooting every 5 sec with black screen, not even entering BIOS. If battery was removed it worked perfectly only on charger. I thought it's a shorted battery so I ordered a new one.
                                  Now with the new one it wont even reboot, but the red battery light is blinking on the laptop. Pressing the power button does nothing. Laptop still works with battery removed.
                                  So to summarize:
                                  1. there is no short
                                  2. Laptop starts only with battery disconnected....
                                  10-26-2023, 07:09 AM
