hp 450 g4 motherboard problem
  • Normunds
    • Feb 2017
    • 12
    • Uk
    19 volts on fet drain, but nothing on source or gate, no shorts to ground on any coils, looked at power management chip and not getting 25v on acdrv. at power connector i am using labaratory power supply 19v and resistor of 100 ohm to 6th leg for ad_id signal. pwm chip: vcc- 18,82v ac det- 2,59v regn- 5.99
    link to boardwiew schematics etc https://failiem.lv/u/n9ah9h829
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: hp 450 g4 motherboard problem
    Does this MB have 2 fets PQ26 PQ27 check the resistance first DSG , you should have 2caps & 1 résister on that line test for any short ? What is the resistance on +PRWSRC ?
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Check if the first or second mosfet is shorted on ohms mode scale 200 must be all open line.
      Good luck
      Steve
      • iT0mT0m
        Problem with motherboard Gigabyte X570S Aero G - no detect RAM
        by iT0mT0m
        I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have...
        12-23-2023, 12:17 PM
      • Xristakis795
        GA-P35-S3 gigabyte motherboard problem after upgrade
        by Xristakis795
        hi to all
        I have the above motherboard on which I had windows xp I upgraded it to windows 10 everything went well just when it rebooted and got updates i saw a message for a very short time that windows is trying to fix a problem they found and then the problem was overcome and all is well
        the computer works normally without any problems on the internet and in everything
        but I found out unfortunately when I had completely cut off the power supply from the network and I went the next morning and plugged it in to turn it on when it went to boot a black screen and the cpu was working...
        12-28-2021, 06:24 AM
      • hopkok
        Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
        by hopkok
        Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
        3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
        I checked for low resistance on coils, no low resistance.
        Anyone with same issue like me?
        Thanks for any help.
        05-24-2025, 04:21 AM
      • Laurimar Rocha
        Beginner looking for help diagnosing LA k092p motherboard problem
        by Laurimar Rocha
        A very old client brought me a recently purchased notebook that suffered a lightning strike and stopped working, as in my region no one does plate repairs, he asked me to help him despite my little experience.
        Acer Aspire Vero notebook (n20c5)
        motherboard FH5AT LA k092p
        The notebook turns on the motherboard LED but does not turn on the fans or even the video or any sign of life beyond that, I tested the power input, the power reaches the battery, I tested some components around the processor, some give 5.7v others give nothing and others are 19v, I haven't found...
        02-10-2024, 06:48 AM
      • cihanpc
        OEM H55 i7 620Lm MOTHERBOARD BIOS PROBLEM
        by cihanpc
        OEM h55 i7 620lm motherboard does not display image. I don't know if it is a bios problem. Is the bios normal?...
        07-03-2024, 08:03 AM
