A1466 no power
  • mon2
    • 14673
    A1466 no power
    re: 820-3437
    Hi. Have an A1466 with no power. Green / orange light on magsafe adapter ok.
    PPBus ok at 8v6
    3v42 ok
    3v3 ok
    Missing 5v0
    Missing vcore 1v02
    Have removed the battery, no difference.
    Vcore cap resistance at 0.312 ohms on vcore rail which seems low ( will confirm again on Monday).
    Concerned that enable for the 5v0 rail is low. Yet the right side of the shared dual regulator is ok and able to produce the 3v3 rail.
    The 5v0 enable is mated with an AND gate which is low input / output, not good as it should be '1'.
    This AND gate is fed to the SMC?
    Could the SMC be damaged?
    What is the remedy for the SMC? Replacement? AliExpress?
    Will review the schematics again to confirm the power on sequencing. Aside from what appears to be a shorted cap on vcore, no liquid damage indicator triggered.
    Any ideas on how to troubleshoot this one?
    Is the vcore rail supposed to be this low on resistance?
    Thanks.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1466 no power
    https://logi.wiki/index.php/Resistan...List#Haswell-U
    You should know by now that you have to go through the list of power rails and check which ones have voltage, which ones don't have voltage and if they are shorted to ground…
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • madan1
      DALI SUB E-12F class D, fluctuating power rail
      by madan1
      Good day everyone.
      I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
      The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
      The normal value of the positive and negative power rails is +/- 43V.
      The positive rail stays...
      10-15-2025, 10:33 AM
