Gateway NV59C works on charger, not on battery
  • tcampbell3492
    • Aug 2019
    Hello. This is my first post here as I am in need of some help with this one. I usually work on Macbooks but trying to fix this one for a family member. This computer originally turned on with AC adapter, but would not charge the battery. New battery was purchased and still same issue. Windows says its charging, but percentage would not increase from 1%. I checked the board and found a short to ground on the BATT+ rail. I found the short was caused by either PC263 or PC264 (I replaced both to be safe). Now it will charge the battery, but will not run off the battery alone. I let the battery charge to 100% and it still turns off when I unplug the charger. With just the battery connected, I am getting cycling voltage on BATT+ and B+ from about 8v down to 2v. With the battery and charger connected, I get steady 12.6v on these rails, and the board starts. I replaced the ISL6251 with a new one, but still have the same issue. I am confused on what could be causing this, so any help is appreciated. I have attached the schematic I am using.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Gateway NV59C works on charger, not on battery
    100% sure the battery is good?
    • tcampbell3492
      • Aug 2019
      The battery is new and I tested the battery alone with my meter and its outputting 11v steady when not connected to the board. Once I connect it to the board, the voltage starts to cycle.
      • piernov
        • Jan 2016
        • 4439
        • France
        Battery being new does not mean it's good, neither does getting a voltage reading with the DMM. It can very well not be able to sustain any current draw.
        • tcampbell3492
          • Aug 2019
          I appears it was the new battery that was bad. I got the original battery and installed it and it charges and runs from the battery only now. Sorry for wasting your time and thanks for the help.
            NVDC charger configuration...
            11-05-2024, 03:28 PM
            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
            Narrow VDC applications where the system power source is
            either the battery pack or the regulated output of the charger.
            This makes the max voltage to the system equal to the max
            battery voltage instead of the max adapter voltage. Operating
            at lower system voltage can improve...
            11-05-2024, 04:43 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • ktmmotocross
            HP 650 G1 - works only with battery+charger but not detecting battery
            by ktmmotocross
            Hello.
            Have this HP 650 G1 that works ONLY when battery first and then attach charger. otherwise it not work with charger or battery only.
            i cannot fing what is wrong with it. ACDET - ok, ADP_A_ID - 3.3V ACPRESS, Mosfets looks ok. even when working board dont see battery . data link on battery is ok 3.3V
            this charging circuit is hard. anybody knows what to measure?
            HP 650 G1
            6050A2566401-MB-A04
            sn - 5CG52238HF...
            02-11-2024, 12:13 PM
