820-00840-A no backlight image present
  • Francisco.s
    • 686
    • Spain
    Hi, this mobo has not enought backlight voltage. (only 13 volts)
    The boost converter does not work, there are no pulses at drain of Q8401.
    BKLT_EN_R voltage is present, (3 volts) and there are BKLT_SDA and BKLT_SCL pulses.
    SMC reset works well with its keyboard.
    I tried PRAM reset, but can not make it work. Same with external keyboard.
    I have no adapter for external display. I have ordered one so I will try PRAM reset via OSX terminal.
    Can someone point me what to do next?
  • mon2
    • Dec 2019
    • 14673
    Re: 820-00840-A no backlight image present
    hi. start with booting up the computer and shine a flashlight (cell phone will do) on the backside of the Apple logo on your display.
    You can also attempt to shine the flashlight from an angle on the front side.
    Move around this flashlight - do you see any of the usual screen icons / desktop stuff?
    If yes, then the LCD display is working but as you have noted, the backlight is not operational.
    Please confirm this first and post your comments.
    Next, power down and place your meter in resistance mode.
    Apply the black (ground) lead to ground (shield is ok).
    Red led onto Cathode of D8410. You will be performing resistance checks with the computer always OFF / NO POWER / NO BATTERY.
    What is the reading? Trying to confirm if the resistance is ok on this rail or if too low then you may have a short circuit inside one of the caps.
    If the resistance is ok then the issue may be U8400 is defective.
    The LP8548B1SQ-04 @ U8400 appears to be common across assorted macbook models so you may be able to pull it off a donor board for testing.
    Please post your updates.
    • Francisco.s
      • 686
      • Spain
      LCD works OK, I can see the logo when booting.
      There is no short circuit, diode mode value is 1.137
      No short, there are 12v at PPVOUT_S0_LCDBKLT. (13 when boots)
      I think you are wright, probably U8400 is defective, but I don't know if there is something else that could be damaged, as the flex cable.
      Is there a flexgate issue in this model?
      Thanks for your help.
      • mon2
        • Dec 2019
        • 14673
        On D8410, check the resistance to ground (not diode value).
        Do this with no power to the logic board and your meter in resistance mode. We are checking for a bad capacitor here.
        Please post the resistance value.
        Not flexgate issue yet. Flexgate is with all voltages are ok including the backlight is at a high reading of 25++ volts but the flex cable cracks and this backlight voltage does not reach the display assembly. The high voltage is used to light up a batch of white LEDs.
        • Francisco.s
          • 686
          • Spain
          The resistance value are a few mega ohms. (without battery nor charger)
          D8410 is also good (13 volts at anode and 12.7 at cathode)
          Time to replace U8400, I think.
          • mon2
            • Dec 2019
            • 14673
            Yes. Starting to agree on the same conclusion.
            You may be able to source this component off another donor board or order from China very soon. I believe some are returning back to work on Monday but all will face a shipping delay due to back log of orders.
            Maybe a local shop has these available for you?
            Please continue to post your updates for future readers.
            • mon2
              • Dec 2019
              • 14673
              The backlight is a custom ic #LP8548 from Texas instruments (former National Semiconductor). This device is controlled over I2C bus (SDA and SCL).
              It is possible that I2C bus is not operational. Check for any possible liquid damage related to the I2C lines.
              If it looks ok just replace this ic and remove the display before powering up.
              Looking forward to your progress report.
              Then check if this voltage rail is high as it should be. Once this is confirmed, then power down and attach the display to confirm the repair was successful.
              • Francisco.s
                • 686
                • Spain
                I would get a fully working Macbook with same motherboard.
                I will try to do comparative measurements and post results.
                There are good pulses in both lines. (pin 15 &16 ic U8400)
                Thanks.
                • Francisco.s
                  • 686
                  • Spain
                  Hi, I've replaced U8400 and boost converter doesn't work.
                  I've also replaced flex edp video cable and doesn't work either.
                  The replaced chip and edp video cable are working OK in the other laptop.
                  Help, I'm running out of ideas.
                  Will try with other bios, just in case......
                  • mon2
                    • Dec 2019
                    • 14673
                    Remove the video cable.
                    Power on - what is the backlight voltage?
                    • mon2
                      • Dec 2019
                      • 14673
                      Post the readings for the attached points (Voltage mode on your meter).
                      • Francisco.s
                        • 686
                        • Spain
                        There are 11.4 volts, with and without video cable.
                        The second motherboard has no voltage without video cable.
                        I'm thinking that Q8400 must be in short-circuit.
                        I will test it and post readings.
                        Thanks.
                        • Francisco.s
                          • 686
                          • Spain
                          After replace Q8400 the problem is solved.
                          All of its pins had the same voltage, so BKLT_SD signal could no control PPVIN_S0SW_LCDBKLT.
                          I don't know how the controller chip is "programmed', but I think it didn't like to sense LCDBKLT_FET_DRV all the time, so it never generate LCDBKLT_SW with this anomalous fedback sensed voltage.
                          • mon2
                            • Dec 2019
                            • 14673
                            Awesome! Thanks for the update.
                            • alro7779
                              Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                              by alro7779
                              Hello there!
                              Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                              08-07-2025, 11:53 AM
                            • Salem Aboshala
                              820-00138-A got image but no backlight
                              by Salem Aboshala
                              Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                              I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                              History: my laptop backlight stopped working without any reason.
                              Symptoms:
                              I have image on screen using my flashlight.
                              I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                              Keyboard backlight still working and can be adjusted normally.
                              Since two days I tried to follow all similar...
                              06-11-2024, 03:02 PM
                            • zaurus81
                              Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                              by zaurus81
                              This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                              The board is equipped...
                              01-16-2025, 03:54 AM
                            • Constantinos
                              Macbook Pro A2442 820-02098 No image but has backlight
                              by Constantinos
                              Hi all
                              I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                              He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                              Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                              Obviously, he decided against this and gave it to me so that I could have a crack at it.
                              From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                              08-24-2024, 09:48 AM
                            • ajgae
                              HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                              by ajgae
                              Hi everyone!
                              First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                              03-06-2025, 09:53 AM
