Lenovo X1 7th Gen Carbon removing WSON Bios
  • davem12
    • May 2019
    • 11
    I am trying to read the Bios on a Lenovo X1 Carbon 7th gen. It has a Winbond W25Q256JVEIQ chip in a WSON configuration. I have not come across this type of chip in the past and there is two very small resistors next pins 1 and 3. I don't want to blow them off when using hot air. Would it be possible to read on-board or does it need to be removed to read correctly?
    Any tips would be very helpful.
    Thank You
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3592
    • slovakia
    Re: Lenovo X1 7th Gen Carbon removing WSON Bios
    did u know what is surface tension?
    • davem12
      • May 2019
      • 11
      I believe the surface tension with solder is it will hold it in place and the chips will align to the solder pads.
      I think one of my issues is I don't have a pre-heater for board rework and I need to apply a lot of hot air to get the solder to melt.
      Thank You
      • MaxonDomkrat
        Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
        by MaxonDomkrat
        Hi everyone.
        I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
        07-30-2025, 01:27 PM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • grimacelord
        Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
        by grimacelord
        Hello there.
        I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
        History:
        1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
        I searched for this error online and discovered...
        03-15-2023, 03:29 PM
      • Gangubasus
        lenovo thinkpad x1 carbon gen 12 bios damp
        by Gangubasus
        Model 21KC-FVT001
        S/N PF-4CQ9FG
        CPU genuine intel(r) cpu 0000
        BIOS N3YET06C (0.06)
        Hello! I need help getting a modified BIOS for my system. Since I have an engineering processor, is it possible to add the microcode of this engineering processor to the latest BIOS for this laptop model? I think since the BIOS is old, that's why the Wi-Fi driver is not installed on Win10 and Win11, the sound is not adjusted (error code 10 in the device manager) and the screen brightness. The laptop also has BIOS chips W25Q512NW and W25Q128JV, how can...
        03-01-2025, 01:25 AM
      • erico
        Lenovo X1 Carbon BIOS not getting voltage
        by erico
        First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
        I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
        So far these are my diagnostics:
        When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
        When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
        If i plug the battery...
        05-02-2024, 02:40 AM
