Need help with 820-00165, power button has to be held long to start!
  • colos85
    • Sep 2020
    • 10
    • Hungary
    Hi Guys!
    I have a 820-00165 that has some strange failure.
    Runs with charger fine, charges battery.
    The problem comes in without charger:
    If battery is attached can be started with power button until it boots into OS.
    After shutting down form os I have to press power button for 10secs to turn it on again. (Power pad does the same, so not a keyboard related problem!)
    If battery is removed then reconnected the board can be turned on with a short press like it should. (Until it goes to OS)
    If charger is connected the power button is always working normally.
    The machine can wake up from battery. However it seems to be it can not go to deep sleep, battery drains fast (goes flat in few days) if I just close the lid. Nothing was connected to the machine while it was in standby.
    Tried another battery, different SSD... Now the board is on my desk, no display, no ssd is installed, OS is loaded from an external disk via USB.
    As per an information found on other forum this "long press start" disables the SMC's AMON/BMON sensing function. I found no faulty parts yet.
    U7100 looks fine current sensing resistors are intact and values are good.
    Any idea? I am totally stuck!
    Thanks in advance!
    Andras
    Best wishes,
    Andras
  • MobileXT
    • Oct 2012
    • 196
    Re: Need help with 820-00165, power button has to be held long to start!
    What is the history of the MBA Water Damage?
    • colos85
      • Sep 2020
      • 10
      • Hungary
      Indicators are white. No corrosion found, never washed with US cleaner. Smc was reflown, so repair attempted before with no success. When i got the board it was not turning on due to a missing rail. When powered on apple logo came up after 20-30 secs, at appr. 40 sec the board turned off. Froze when nvram reset done, but sometimes it was able to boot. Known good bios file, ME cleaned, serial matched, burnt on a tested eeprom, voila running great. Except for the battery mistery.
      Best wishes,
      Andras
      • MobileXT
        • Oct 2012
        • 196
        Check the resistance of the R7121 and R7122 they should be Both 10 ohms and R7151 2.2ohms, R7152 O ohms
        • MobileXT
          • Oct 2012
          • 196
          Also check R7006 for resistance should be 4.7 ohms and D7005 for shorted
          • colos85
            • Sep 2020
            • 10
            • Hungary
            Hi MobileXT,
            Thank you so much. All of them are checked and having correct values.
            Best wishes,
            Andras
            • MobileXT
              • Oct 2012
              • 196
              Hi MobileXT,
              Sounds like SMC issue. Try run the built-in diagnostic tools. Power off the laptop and turn on while holding the D.
              • colos85
                • Sep 2020
                • 10
                • Hungary
                Hi MobileXT,
                Apple diagnostics found nothing. I have replaced the SMC, known good one (year matches), same behavior. Why the issue comes on ONLY after booted at least to the login screen? What changes then?
                As per Istat menus the current values are correct compared to any other logic board. Could this be a corrupt EFI? Because it had to be changed previously... (cleaning done).
                Thank you!
                Best wishes,
                Andras
                • david zhao
                  • May 2017
                  • 9
                  • australia
                  [QUOTE=colos85;1020181]Hi MobileXT,
                  I have a logic board 820-00165 2017 model, it behaves exactly as you mentioned. If the MacBook air has booted to login screen, and shut down late on, then the only ways to turn it back on are either connecting the AC power cord, or by holding down 8-10 seconds if no ac power available.
                  If AC power is connected, the 820-00165 always turns on normal way by one touch on the power button.
                  I have tried reflowing SMC, loaded high sirerra, and then upgrade it to high sierra 10.13.6 (this means any EFI fix automatically if the EFI has been corrupted).
                  Tried the logic board in another chassis of MacBook air, no luck
                  Anybody has any ideas? all helps will be much appreciated!
                  Kind regards
                  David
                  • david zhao
                    • May 2017
                    • 9
                    • australia
                    Hi Andreas, have you found a solution for your 820-00165 problem? I have the same issue as yours. When with battery power, if the system shut down from OS, then I have to hold down power button for 8-10 seconds to turn it on. If battery disconnected, then reconnected, it can power on normally(one touch on the power on button). If the AC adaptor is connected, then it can always turn on normally.
                    if you have a solution for this, please let me know. I can do board level repairs.
                    Kind regards
                    david
                    • colos85
                      • Sep 2020
                      • 10
                      • Hungary
                      Hi David,
                      I still have this board with the same problem. Unfortunately no solution yet. SMC replaced, as mentioned above, checked resistors around u7100, u5600/01... With the same values an other board is running fine.
                      Now I am trying to find if there is some power rail that remains on in a "lower" state. As I know If any usb/sd card is connected deep standby is forbidden. What I can imagine, if this happens BMON says too much current is taken in off/standby state, where that current value is impossible.
                      Sorry for the late reply, if I can find something let you know.
                      Regards, Andras
                      Best wishes,
                      Andras
                      • colos85
                        • Sep 2020
                        • 10
                        • Hungary
                        Re: SOLVED! Need help with 820-00165, power button has to be held long to start!
                        Hi Guys! SOLVED!
                        U8020 has failed. I was measuring resistance around Q5510 and found that PM_SLP_SUS_L was at 1,5kohms. It should be around 80k to ground (value stolen from a known good 00165). Either q5510 or u8020. or pch...but I was lucky!
                        Thanks for the support!
                        Regards, Andras
                        Best wishes,
                        Andras
                        • david zhao
                          • May 2017
                          • 9
                          • australia
                          Hi Guys! SOLVED!
                          Regards, Andras
                          Thank you for letting me know. The MacBook logic board has been long gone, but I am sure the knowledge will help me in the future's repair.
                          Have a great New year!
                          Best regards,
                          David
                          • BTubbs200
                            Dell Latitude 5420: No charge, no boot; amber LED for as long as the power button is held.
                            by BTubbs200
                            Dell Latitude 5420 P137G
                            Board model LA-K491P REV A01
                            Laptop is stone dead and only reacts to the power button being held while the charger is plugged in, in which case a dim amber LED fades in and immediately fades out when I let go. Battery being plugged/unplugged does not change anything.
                            CMOS battery was removed and reinstalled; no change.
                            No shorts to ground have been identified on the board whilst probing the power rails in resistance mode. No visibly damaged components.
                            No indication that the CPU is receiving power; CPU fan does not activate.
                            Of...
                            01-23-2025, 10:45 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Andreasbest
                            Dell Latitude 7410 dead and amber light as long power button is pressed.
                            by Andreasbest
                            Hello.
                            I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                            Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                            Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                            Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                            12-21-2024, 02:02 PM
                          • techpointhull
                            HP OMEN 16-WF0032TX NO Power unless the button is held and AC adapter connected
                            by techpointhull
                            Hi Guys,
                            Got a weird one here. I have a HP OMEN 16-WF0032TX that's in my shop for no power. If I disconnect the battery, and the AC adapter and hold the power-on button on the keyboard, when I connect the adapter the laptop powers on. If I shutdown and close the lid, once I re-open the lid and press the power button, no power. If I shutdown and keep the lid open, when I press the button the laptop powers on.
                            I have checked around the display connector if I can see anything that doesn't look right, its like an issue with the lid sensor. Has anyone seen this before?...
                            12-10-2023, 12:32 PM
                          • reessi
                            Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                            by reessi
                            With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                            No corrosion any where!
                            Tried a replacement power button off ebay and the same.
                            Very occasionally it will work with the power button connected!
                            Same results with or without the battery.
                            Can it be a fault with the Audio board or the mainboard?
                            The touch Id assembly connects through the Audio board first then to the Mainboard.
                            Flex...
                            06-26-2024, 03:31 PM
