Hard Drive Not Detecting HP ZSO50 LA-A99P REV 1.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi the unit wont detect on the hardrive ive check the output voltage of the HDD connection but im missing 3V pin 10 no voltage
    BOARD : ZSO50 LA-A992P REV 1.0 2014-04-14
    LAPTOP : 15-R109NX REV 2212-110
  • mon2
    • Dec 2019
    • 14677
    Re: Hard Drive Not Detecting HP ZSO50 LA-A99P REV 1.0
    Does the hard drive get detected on a different system?
    Is the voltage that is missing available before the series resistor?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes sir yes no resistor sir
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        For the Hdd to work, the voltage of +5VS_HDD1 must be sufficient.
        I'm not happy to be so strong. because it's not humanly
        • pooya_pm
          • Jan 2021
          • 259
          • iraq
          Originally posted by kalilinux25
          hi the unit wont detect on the hardrive ive check the output voltage of the hdd connection but im missing 3v pin 10 no voltage
          board : Zso50 la-a992p rev 1.0 2014-04-14
          laptop : 15-r109nx rev 2212-110
          send bios backup and photo ob numner mainboard
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
          • tmcw
            PC case - Hard drive rails
            by tmcw
            A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
            So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
            I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
            Now, the case is a CiT Gaming Case, and...
            05-22-2022, 12:04 PM
          • ash91
            Hp pavilion 15 not detect hard drive
            by ash91
            Hello gentelmen .... this is my first post and sorry for my bad english,
            so my proplem is my laptop keep losing hard drive even if i but the
            hard disk in the cady (the box that can replace the dvd rom with hard disk)
            when i turn the laptop on the massage that said no boot media found pop on
            the hard disk is fine and to be sure i try another hard
            i also update my bios to the last update
            the 5 volt is present on the hard connector on the motherboard
            the dvd rom work fine when i but a windows dvd in it
            also when i boot from flash...
            06-07-2023, 01:45 PM
          • sureshbobby
            Dell Inspiron 1545 not detecting hard drive and dvd drive
            by sureshbobby
            Hi Techies
            Need help and advice on my laptop dell inspiron 1545
            any hard drive and dvd not detecting
            please help
            11-10-2021, 06:43 AM
          • karto95
            Repairing a Seagate hard drive with damaged logic board
            by karto95
            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
            If anyone has any suggestions or experience with this...
            03-21-2023, 04:05 AM
