Hard Drive Not Detecting HP ZSO50 LA-A99P REV 1.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi the unit wont detect on the hardrive ive check the output voltage of the HDD connection but im missing 3V pin 10 no voltage
    BOARD : ZSO50 LA-A992P REV 1.0 2014-04-14
    LAPTOP : 15-R109NX REV 2212-110
  • mon2
    • 14333
    Re: Hard Drive Not Detecting HP ZSO50 LA-A99P REV 1.0
    Does the hard drive get detected on a different system?
    Is the voltage that is missing available before the series resistor?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes sir yes no resistor sir
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        For the Hdd to work, the voltage of +5VS_HDD1 must be sufficient.
        I'm not happy to be so strong. because it's not humanly
        • pooya_pm
          • Jan 2021
          • 254
          • iraq
          Originally posted by kalilinux25
          hi the unit wont detect on the hardrive ive check the output voltage of the hdd connection but im missing 3v pin 10 no voltage
          board : Zso50 la-a992p rev 1.0 2014-04-14
          laptop : 15-r109nx rev 2212-110
          send bios backup and photo ob numner mainboard
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
          • tmcw
            PC case - Hard drive rails
            by tmcw
            A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
            So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
            I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
            Now, the case is a CiT Gaming Case, and...
            05-22-2022, 12:04 PM
          • ash91
            Hp pavilion 15 not detect hard drive
            by ash91
            Hello gentelmen .... this is my first post and sorry for my bad english,
            so my proplem is my laptop keep losing hard drive even if i but the
            hard disk in the cady (the box that can replace the dvd rom with hard disk)
            when i turn the laptop on the massage that said no boot media found pop on
            the hard disk is fine and to be sure i try another hard
            i also update my bios to the last update
            the 5 volt is present on the hard connector on the motherboard
            the dvd rom work fine when i but a windows dvd in it
            also when i boot from flash...
            06-07-2023, 01:45 PM
          • sureshbobby
            Dell Inspiron 1545 not detecting hard drive and dvd drive
            by sureshbobby
            Hi Techies
            Need help and advice on my laptop dell inspiron 1545
            any hard drive and dvd not detecting
            please help
            11-10-2021, 06:43 AM
          • ChaosLegionnaire
            bug of the month: write caching setting for the hard drive in device manager
            by ChaosLegionnaire
            i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
            so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
            10-06-2019, 01:39 PM
