Lenovo G50-80 turns off after few seconds.
  • Bam0082
    • 8
    • FRANCE
    Hello everybody
    I am facing to a consistent problem with my mother's Lenovo G50-80 with ACLU4-NMA361 motherboard. CPU is Core i5 5200U and GPU R5 M330. When I plug on AC adapter or turn it on by button, power led (LED4) is on and fan starts to spin and all stops few seconds later.
    First, I removed BGA GPU R5 M330 because package was physically brocken. NO CHANGE
    I measured several voltages following what should be normal power sequence :
    A1) VIN : 20V
    A2) B+ : 20V
    B2) +3VLP : 3.37V
    A3) EC_ON : 3.37V
    B3) ON/OFF 3.37V button not pressed, 0V when pressed
    A4) +3VALW : 3.38V
    1) DPWROK_EC : 3.37V
    2) PCH_PWR_EN# : 3.38V
    3) +3VALW_PCH : 3.37V
    4) PCH_RSMRST#_R : 3.37V
    5) PBTN_OUT# after button press : 3.3V for 350ms, 0V for 100ms, then 3.3V continuous
    6) PM_SLP_S3# : 3.3V for 300ms and then 0V
    PM_SLP_S4# : 3.3V for 300ms and then 0V
    7) SYSON : 3.3V
    8) SUS_VCCP : 3.3V for 400ms and then 0V
    9) SUSP#: 5V for 400ms and then falling to 0V
    +CPU_CORE : 1.65V for 400ms and then 0V
    I removed PJ707 (solder shunt B+ to +VGA_B+), changed nothing.
    When I remove PQ40(CPU phase High-side MOSFET), the laptop seems to NOT turn off (power led still brighting, voltages present,...) but obviously, +CPU_CORE is 0V… so cannot boot.
    Idem when I remove PJ708 (solder shunt B+ to PQ40 drain) or (PL9 self of the phase).
    I don't find any short, I removed PQ40, test it : was OK, change it, same result.
    Strange fact : On circuit, measured resistance on PQ40 between source and drain is more than 250kohms but when I plug AC adapter, remove it and measure this resistance, it drops to 1.2ohms for lots of minutes (problem or capa discharging ?)
    I don't know what to do, please could you help me ?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo G50-80 turns off after few seconds.
    History? Known good compatible RAM? Tried to flash the BIOS?
    • Bam0082
      • 8
      • FRANCE
      It has made this suddenly. My mother has given it to my father but he broke the GPU trying to remove the heatsink. I tried different RAM modules DDR3 ans DDR3L known good. I flashed the BIOS with RT809H but not sure that the dump is good. NO CHANGE
