a1706 820-00239-A boots up just sometimes
  • Harryrepair
    • Jul 2016
    • 82
    Hello all,
    i have got a Macbook a1706 which boots up just sometimes.
    PPBus_G3h 13.06V
    PPVCCSA_S0_CPU 1.1V
    CPUVR_PGOOD 3V
    Vcore 0V
    All other Power Rails seem to be OK.
    Sounds to me like a bad solder connection.
    Any hint where and how to search ?
    I thought on reballing U7100 maybe.
    Kind Regards
    • 20695
    Re: a1706 820-00239-A boots up just sometimes
    Whats the history of it,any liquid damage etc .Have you gone through the list of power rails and checked everything
    • Harryrepair
      • Jul 2016
      • 82
      I measured all Power Lines.
      Attached my results.
      • piernov
        • Jan 2016
        • 4435
        • France
        Cpu_vr_en_r?
        • Harryrepair
          • Jul 2016
          • 82
          Cpu_vr_en_r 3.24 v
          On charger:
          20.3 V
          consumption 0.15a
          • piernov
            • Jan 2016
            • 4435
            • France
            Try to flash the BIOS.
            • Harryrepair
              • Jul 2016
              • 82
              How do i do that?
              This is new to me.
              • Jenzo
                Apple A1706 - Boots and shuts off
                by Jenzo
                Hey everyone,
                Working on a macbook A1706, board number 820-00239-A.
                When trying to turn it on you hear the chime, but get no image whatsoever, and after about 10-15 sec it'll turn off (monitoring usb amp meter, it goes back to 15v 0a. I'm using a 45W charger btw, can't find my 85W atm).
                As far as I can tell all 3V3 an 5V lines come up, up until S0, and then go back to 0V. G3H stays stable at 13V.
                Put it under the thermal cam, only L7030 gets a little hot (35c), but nothing out of the ordinary.
                Where do I go from this? I'm...
                10-11-2022, 11:16 AM
              • pepebmx
                ThinkPad T14 Gen 3 - Boots Only on Charger
                by pepebmx
                Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                Laptop: Lenovo ThinkPad T14 Gen 3
                Serial No: PF-437QTG
                PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                Extracted BIOS: Will upload tomorrow
                BIOS Password: None Issue Description:
                • Boots only on charger → Works normally when connected to AC.
                • With battery connected:
                  • Fan spins at full speed, no display.
                  • Not all voltages present (some missing).
                • Battery charges correctly (detected in Windows, shows percentage).
                • When battery is plugged in while in Windows:
                  • Laptop shuts
                05-08-2025, 01:53 PM
              • Danielreinaa
                HELP need password bios Macbook A1706
                by Danielreinaa
                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                09-07-2024, 03:47 PM
              • moderator
                A1706 - emc 3107 bios
                by moderator
                a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
                Serial number is C02STA7EHF1P
                its A1706 - emc 3107...
                05-17-2024, 07:00 AM
              • abajor
                A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                by abajor
                Having this very weird issue.
                The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                I swapped with a working screen from an A2141 waiting for parts.
                The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                04-27-2024, 01:37 PM
