Acer Spin 5 SP513-51 New battery not charging
  • mrattitude
    • Dec 2020
    • 21
    • Scotland
    This laptop is not charging the battery, I am aware of the battery tactile switch on the bottom of the motherboard.
    I have reset the BIOS etc.
    I cannot find a boardview for this model - I suspect a faulty charging IC
    Any advice would be appreciated.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Acer Spin 5 SP513-51 New battery not charging
    Voltage on all pins of charging ic ?
    Voltage on battery connector pins ?
      • 21886
      Schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41 Post the full motherboard model number
      • mrattitude
        • Dec 2020
        • 21
        • Scotland
        Thank you for the reply Stingerchamp.
        I have not been able to find any motherboard ID, there is zero voltage on the battery pins and I have not been able to locate the charging IC.
        There is a tactile switch on the bottom of the motherboard that needs to be pressed to allow the battery to charge - so it is difficult to measure anything battery related.
        • mrattitude
          • Dec 2020
          • 21
          • Scotland
          Update: There is an APL5930 - shown on the attached image but there is zero voltage on any pin.
            • 21886
            The motherboard part number is on the other side.Its a Wistron DRIFT_KBL .
            There`s a request for the boardview already but nothing has been posted yet....
            https://www.badcaps.net/forum/showthread.php?t=89293
            Have you tested the switch to make sure its working ok.
            • mrattitude
              • Dec 2020
              • 21
              • Scotland
              Thank you for the reply, yes the switch is working.
              If I hold down the switch and plug in the charger I get 12v on the battery connections for a few seconds then it goes to zero.
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                Seems fully charged
                Check without adapter Plugin voltage gets stable?
                • mrattitude
                  • Dec 2020
                  • 21
                  • Scotland
                  NO, it is a new battery and has zero charge. The laptop will not power on without the charger.
                  The laptop will also not charge the old battery - initially I presumed the battery was needing to be replaced.
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    Ok
                    With adapter plugin check charging ic all pins
                    Voltage
                    What is written number on charging ic
                    • mrattitude
                      • Dec 2020
                      • 21
                      • Scotland
                      With charger plugged in no voltage on any pins.
                      IC: APL5930
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        Motherboard model/part number
                        Written on motherboard ?
                        • mrattitude
                          • Dec 2020
                          • 21
                          • Scotland
                          SMDFlea; The motherboard part number is on the other side.Its a Wistron DRIFT_KBL .
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Lol
                            Fine did not notice anyhow
                            I asked because you share ic which is a ldo regulator not a charging ic,
                            Take a big picture of motherboard and post here
                            Charging ic has markings starting with bq or bq24735 etc mostly
                            • mrattitude
                              • Dec 2020
                              • 21
                              • Scotland
                              Thanks for your input, I have attached some images.
                              There is one chip that shows some damage but I cannot read the information on the top.
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                Images are not clear
                                White dot mark on chip shows it is bios chip but it is working fine since laptop is functioning
                                Can you take picture of back or try to find number something like nbgkxxxx etc written in big size font
                                Can you verify it is drift skl motherboard
                                Is this your motherboard
                                https://www.ebay.com/itm/Acer-Spin-S...kAAOSwG8NeZqss
                                  • 21886
                                  He seems reluctant to take the motherboard out .
                                  • stingerchamp
                                    • Sep 2020
                                    • 425
                                    • Pakistan
                                    Okay thanks it is his choice
                                    Good luck
                                    Enc KBC and charger is at back side
                                    • mrattitude
                                      • Dec 2020
                                      • 21
                                      • Scotland
                                      Sorry guys, Thank you for your input. I am working so have not had a chance to do it yet.
                                      SMDFlea - No that is not my board.
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • abrahim110
                                        [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                                        by abrahim110
                                        ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                                        I have an Acer Aspire 5 A517-52G-53NB laptop.
                                        The onboard (soldered) RAM was faulty, so I physically removed the chip.
                                        I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                                        โœ… System status:
                                        • BIOS mod is done (SPD removed)
                                        • Laptop boots to Windows normally
                                        • RAM is detected and stable
                                        โŒ Problem:
                                        The battery is not charging:
                                        • Power adapter
                                        08-06-2025, 06:15 AM
                                      • titomno2
                                        Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                                        by titomno2
                                        Hi guys,
                                        I currently trying to figure out why the laptop of my friend did not charge.
                                        It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                                        At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                                        I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                                        My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                                        06-11-2024, 11:52 AM
                                      • Julian Bailey
                                        HP ProBook 445 G8 Battery not charging
                                        by Julian Bailey
                                        Hi all
                                        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                        I have gone around the board with a MM and cant find anything
                                        Windows shows the battery fine,...
                                        10-11-2024, 10:34 AM
                                      • Source Code
                                        Acer Nitro 5 not charging but working with battery
                                        by Source Code
                                        Hello Everyone
                                        First I must say I am trying to learn electronics. I have an Acer Nitro 5. Board is LA-861P. The laptop does not charge but when it has battery life it would power on and work fine. I have use a multimeter to check the charger and I get 19v.
                                        Input on PBQ3 mosfet is 19v but no output or very low voltage. The voltage on PCZ65 and PCZ48 is 2v and it keep dropping after putting the charger for a few second. Battery pin would give like 0.200v declining.
                                        If I put the laptop off for like 2-3 months it would start charging again but I need to do this...
                                        11-17-2024, 12:44 AM
