No display ACER DAZ8ADMB6D0 REV D
    Re: No display ACER DAZ8ADMB6D0 REV D
    Originally posted by stingerchamp View Post
    KBC pin 11 check with button pressed
    Check pu9 pin 14 button pressed
    It should not be zero if zero means 3v is not reaching to KBC
    Check capacitor c65 both sides and resistor r814
    pin 11 0v pressed 3.3v then 0v again
    pin 14 0v presed 1.8v then 0v again
    no voltages sir on c65 both sides and also r814 sir
      C65 can not be zero
      Check c65 without any power in beep mode for short
      After that if c65 beeps replace it
      Then with power check with button pressed resistor r814 voltage
        C65 can not be zero
        c65 no beep no shorted
        r814 voltage 0V pressed goes 3.3v then zero
          Check pu9 17 and 18 pins before pressing and after pressing
          Pu9 pin---17 is 3vpcu always present check stable or not
          Pu9 pin ----18 is 3vs5 check stable or not
            pu9 pin 17 has 3.3v stable if pressing power 3.3v dont change
            pu9 pin 18 has 0v if pressed 3.3v then goes 0v again
              Check pin---11, 26,24,13 power stable
              Measure voltage for 10 sec at each pin
              You have found the problem, 3vs5 supply is dropping which is going every where in motherboard
              Pin11--vcc
              Pin13-- rsmrst
              Pin 26--en1.5a --s5_on signal
              Pin24---suspwrdnack
                Pin11--vcc
                Pin13-- rsmrst
                Pin24---suspwrdnack
                PIN 11 HAS 5V
                PIN 13 notice some problem here sir based on image
                I got 3.3v stable but in ic pin 13 nothing
                pin 26 0v
                pin 24 has 0v sir
                  Vcc 5v is stable?
                    Vcc 5v is stable?
                    yes stable sir
                      Check check pin 77 of kbc s5_on stable
                        0v sir in pin 77 kbc
                        when button press nothing happens
                          So s5_on is missing
                          Check at pin 26 of pu9, before pressing and after pressing button
                            So s5_on is missing
                            BEFORE 0V
                            after press 2.2v then goes zero
                              3.3 should be here
                              2.2 is very low
                              Remove pu9
                              and with DC supply at c65 capacitor Provide 3v and check at c65 voltage drop at multimeter
                              If drops something other is faulty
                              If stable pu9 is faulty , change
                                3.3 should be here
                                2.2 is very low
                                Remove pu9
                                pu9 remove
                                c65 pump with 3v voltage is stable at dc supply 15 miiliamp consuming
                                  Earlier supply was dropping?
                                    yes dc supply 38 to 15 miiliamp then keeps flactuating at 15 to 20 milliamp range
                                      Ok change pu9
                                        Ok change pu9
                                        ok sir I need to order it and it will arrive 1 moth
                                          Ok before you do that
                                          Let's confirm it again by different method
                                          With DC supply this time check at pc16 voltage stable or drops, same previous method voltage 3.3v
