No display ACER DAZ8ADMB6D0 REV D
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    #81
    Re: No display ACER DAZ8ADMB6D0 REV D
    Originally posted by stingerchamp
    Ok before you do that
    Let's confirm it again by different method
    With DC supply this time check at pc16 voltage stable or drops, same previous method voltage 3.3v
    with out the pu9 ic sir?
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      #82
      Yes at pc16 connected to pin 18
      • kalilinux25
        • Mar 2018
        • 2093
        • ZAMBOANGA SIBUGAY
        #83
        Yes
        it gets 13 miiliamp the flactuate 17miliamp
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          #84
          Voltage not current on multimeter , check voltage at multimeter stable
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            #85
            voltage is stable sir
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              #86
              Ok confirmed pu9 need to be changed
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                #87
                just a noob question sir how did we found out ?
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  #88
                  Pc16 is attached to pu9 3vs5
                  This supply was dropping we detected
                  Two reasons
                  Either ic or any other components faulty
                  If voltage dropped at pc16 it means ic is ok even after we removed
                  If voltage stable now ic is removed so no connection with other components of ic so proved ic was faulty
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    #89
                    Two reasons
                    great it help me a lot to understand more about this new ic sir thank you
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      #90
                      Remember whenever 3v ic get faulty there is 60 percent chance of kbc also need to be replaced
                      Let's wait
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        #91
                        Let's wait
                        that was also im thinking the kbc may be damage
