No display ACER DAZ8ADMB6D0 REV D
    RSMRST# 3.3V
    SOC_DRAM_PWROK 1.3V
    RTC CLOCK 32.768KHZ PRESENT
    Y7 19,2MHZ OK\ Y8 25MHZ OK
    DRAMRST# 1.3V
    What is my missing wont display on my board?
    Re: No display ACER DAZ8ADMB6D0 REV D
    Make sure dramrst pin 30 of ram slot is 1.35
    Voltage on ram coil and power good
    Check cpu_powerok and pltrst#
    Have you checked external display
      Because of very busy I forgot to test the external display it was working I will try to test with a new lcd thanks for informative response sir
        sir my battery is not charging charging led will just on but not consuming voltages in my becnh supply
        BQ24737RGRR (pu8)
        PINS NAME OUTPUT
        6 ACDET 2.6V
        20 VCC 18V
        5 ACOK# 0V
        8 SDA 3.3V
        9 SCL - 3.3V
        11 DM# 3.3V
        15 LCDRV 0V
        19 PHASE 2.7V
        18 HIDRV 2.7V
        17 BTST 5.9V
        16 REGN 6V
        1 ACN - 18V
        2 ACP - 18V
        Is my charging ic dead?
          Measure voltage on all pins of charging ic
          Measure voltage on pj6 battery connector
          Voltage on acin
          Acpress
          Check voltage on boot capacitor pc71
          Lcdrv low check again
            Voltage on acin
            Acpress
            3 -cmpout - 0v
            4 cmpin - 0v
            7 -Iout - 0V
            10- ilim - 0v
            12 -srn - 2.7v
            13 -srp -2.7v
            14 -pgnd - 0v
            20 -vcc -18v
            PJ6 CONNECTOR
            1 -2.7V
            2 -2.7V
            3 -0V
            4 -3V
            5 -3.3V
            6 - 0V
            7 -0V
            8 -0V
            PC71 from pin 17 5.9 from pin 19 2.7v
              Is it 18v adapter charger?
              Acin signal voltage?
              Acpress signal voltage?
              If ok
              Then check pd8 diode it should have voltage at other side,.
              In normal case voltage is battery voltage+ regn6v so in your case it should be 2.7v + 6v = 8.7v
              Check voltage at pc 57
              I-out voltage is zero means something wrong
              Check pr149
              Check pr14
              Check pc63 , pc72 caps for short
              Check pd10 zener diode at pj6 mbdata is missing
                If ok
                Check pr149
                Check pr14
                PD8 has same voltage up and lower has 6v checking pc57 voltage it has 6v
                also
                PR149 no voltage
                PR14 no voltage
                PC63 is shorted
                PC72 is shortted
                PD10 is ok no shorted to ground
                  Check voltage drop between ACP and phase pins
                  Check cap outside if still short replace
                  Check high side mosfet voltage at all pins
                  Vin is available at hi side mosfet?
                  Voltage on 2nd DC in mosfet
                    PQ28 PIN 5 has 18v 1234 has 2.7v pin
                      Pq28 pin 5 voltage 18v should pass n channel mosfet and reach via pin 123 to phase
                      Check resistance between gate 4 and source pins 1,2,3
                      Voltage difference between ACP and phase?
                        Btst pin is +ve input supply for high side mosfet internal circuit opam
                        So we should have exactly 6v at btst not 5.9
                        SDA scl has 3.3 voltage but mbdata at pj6 is 0v
                        If pd10 is ok it so be 3.3v at pj6 pin mbdata
                        For battery detection check pr129 100 ohm resistance value in ohms it must have been increased
                        This pin is necessary for correct battery plugin detection
                          pq28 resitance value not shorted
                          yes phase 2.7v acp 18v
                            PR129 vlaue is 100 correcty
                              Replace shorted caps
                              and pq28
                              and diode
                                and pq28
                                and diode
                                I dont have diode sir I just replace the shorted caps and pq28 testing pin 123 has 2.7v pin 4 has 2.7v also
                                  and pq28
                                  and diode
                                  PJ6 CONNECTOR
                                  1 -2.7V
                                  2 -2.7V
                                  3 -0V
                                  4 -3V
                                  5 -3.3V
                                  6 - 0V to 6v now
                                  7 -0V
                                  8 -0V
                                    and pq28
                                    and diode
                                    the unit now wont power
                                    5vand 3v is present U22 PPIN 8 NO voltage reading +1.8V_S5
                                      Sad
                                      Step by step
                                      Check adapter is okay and have 18v present
                                      Check voltage on DC Jack connector available and check voltage on DC MOSFETs available
                                      Then check
                                      Voltage on charging ic pins
                                      Voltage on power button
                                        Sad
                                        Step by step
                                        Then check
                                        dc supply showing no amps consuming
                                        3.3v pin 3 of CN7
                                        1-18v
                                        2-18v
                                        6-2.6v
                                        8-3.3v
                                        9-3.3v
                                        11-3.3v
                                        12-2.6v
                                        13-2.6v
                                        16-6v
                                        17-6.4v
                                        18-2.7v
                                        19-2.7v
                                        20 -18v
                                        3,5,7,10,14,15, has 0v
