No display ACER DAZ8ADMB6D0 REV D
    Re: No display ACER DAZ8ADMB6D0 REV D
    Voltage on all pins of pu9
    Voltage on pq11
    Then
    Voltage on pq22, pq17,pq18
    Rsmrst#
    RTc_vcc and s5_on
      Voltage on pq11
      Then
      Rsmrst#
      RTc_vcc and s5_on
      PU9
      1,2- 3.3V
      11-5.1V
      17-3.3V
      20,21-3.3V
      NO VOLAGE pins
      3,4,5,6,7,8,9,10,12,13,14,15,16,18,19,22,23,24,25,26,27,28
      icant locate the pq11 sir no marking in the board thats why Im having a ahrdtime
        When you press power button
        Voltage goes down to zero at nbswon#
        Rsmrst# voltage?
          Rsmrst# voltage?
          Yes sir goes down to szero 20miliamp then zero rsmrst# no voltages
            PMU_RSMRST# at r37 check
            If rsmrst# is zero
            Your bios is likely corrupted but not confirm
            DNBSWON# signal voltage
            ACIN voltage signal at pq6 mosfet
            Check all three voltages and reply
              If rsmrst# is zero
              pin 13 PU9 PMU_RSMRST# 3.3v
              pin 123 DNBSWON# u8
              acin HAS 0V voltage sir I tried to flashed the bios same issue
                At pu9 rsmrst# 3.3 v but in previous post you mentioned no voltage on this pin
                NO VOLAGE pins
                3,4,5,6,7,8,9,10,12,13,14,15,16,18,19,22,23,24,25, 26,27,28
                At r37 what is pmu_rsmrst# value?
                Dnbswon u8# ?
                  NO VOLAGE pins
                  Dnbswon u8# ?
                  pmu_rsmrst# pin 13 of pu9 has 0v sir
                  dnbswon at EC chip pin 123 has 0v
                    Check voltage at pin 123 value change with button pressed and without pressed
                      sorry sir the pin123 has 3.3v sorry
                        What happened
                        Measure same pin when
                        Power button pressed
                        Voltage
                        and
                        Power button not pressed
                        Voltage
                        This should go to 0 when power button pressed
                        Before pressing it should be 3.3
                          What happened
                          Voltage
                          and
                          Voltage
                          it goes to zero sir if i press the powerbutton isr
                            Ok no issue
                            Just flash the bios
                            Replace bios chip
                              Ok no issue
                              Just flash the bios
                              Replace bios chip
                              already change same bios ic nothing happend
                                Ok
                                Check voltage on bios pins
                                Check voltage on pq6 at all pins
                                Then we will start measuring all signals
                                What is condition of laptop turn on or not?
                                  Ok
                                  all bios pins has 0v voltages also all pins of pq6 has 0VSsir
                                    Ok
                                    Check voltage on q42 pin 3 and tell
                                    Check voltage on u11 all pins
                                    Measure and report back like this
                                    Pin1 ---
                                    Pin2----
                                    and so on all pins
                                      Ok
                                      Pin1 ---
                                      Pin2----
                                      and so on all pins
                                      pu11 all pins check but cant locate the q32 sir
                                      Pin1 ---1v
                                      Pin2----0v
                                      Pin3---3.3v
                                      Pin4----0v
                                      Pin5 ---0v
                                      Pin6----3.3v
                                      Pin7 ---0v
                                      Pin8----0v
                                      Pin9 ---4.7v
                                      Pin10----0v
                                      Pin11 ---0v
                                      Pin12----18v
                                      Pin13 ---5v
                                      Pin14----0v
                                      Pin15 ---0v
                                      Pin16----0v
                                      Pin17----4.7v
                                      Pin18----0v
                                      Pin19 ---0v
                                      Pin20----3.3v
                                      sorry I cant locate the pq42
                                        At pu11 you have 4.7 volt at pin9 and pin8 you have zero
                                        Voltage on coils pL 11 and PL13
                                        and also voltage on capacitor c124
                                        Measure and reply
                                        You don't have U11 ic? on this motherboard check schematic for u11 ic
                                        U11 ic not pu11 ok
                                          Measure and reply
                                          U11 ic not pu11 ok
                                          pin 8 has 3.3v sir i dont know after second time itshows voltage pin 9 has 8v
