No display ACER DAZ8ADMB6D0 REV D
    Re: No display ACER DAZ8ADMB6D0 REV D
    Originally posted by stingerchamp View Post
    At pu11 you have 4.7 volt at pin9 and pin8 you have zero
    Voltage on coils pL 11 and PL13
    and also voltage on capacitor c124
    Measure and reply
    You don't have U11 ic? on this motherboard check schematic for u11 ic
    U11 ic not pu11 ok
    pl11 has 3.3v pl13 has 5v
      Measure and reply
      U11 ic not pu11 ok
      u11 all pins has 0v same with u15
        Seems 3v also missing
        Always report fully
        You did not check voltage on coils
        PL 11 and PL13
          Always report fully
          PL 11 and PL13
          pl11 has 3.3v pl13 has 5v sir sorry
            Good
            It means 3v 5v ic is okay
            But U11 pins have zero voltage strange
            U11 is converting ,3v into 1.8v_s5
            Measure voltage on U11 pin 8 and Pu11 pin 8
            Relax and count pin correct
              Good
              rechecking the u11 pins nothing sir 0vs pin 8 of pu11 has 3.3v sir
                Check voltage on pq12 all pins
                It is a 3v switch supply
                Check voltage on all pins of pq 41
                It is a 5v switch supply
                Measure and reply with pins
                  i cant loacate the pq12 sir on the board also the pq41
                    Pq12 is a mosfet which is providing +3v to U11 not pu11
                    Check page 35 schematic
                      this two , mosfet has 5v on both 5 pins 1234 has 0vs
                      the two mosfet is
                      e070bn mosfet
                        Is this pq12
                          Is this pq11?
                          not so sure sir I think this is the pq41 sir not the pq11 the pq11 is a AO3404 transistor
                            Marking on board?
                            Ok
                            Now we getting close
                            Did you find pq12?
                              Marking on board?
                              Ok
                              Did you find pq12?
                              nope sir I cant find the pq12 sir sorry that two mosfet is the only mosfet in the board nothing else the other is part o the 5v and 3v system msofet this two I cant sure if where is the pq12
                              https://www.badcaps.net/forum/showth...ht=DAZ8ADMB6D0
                              post 6 sir sample of my board same no marking on it
                              https://www.badcaps.net/forum/attach...4&d=1496140466
                                Okay 5v is also ok
                                No problem
                                If you don't mind can you again measure pu9 pins 9, 14 and 18
                                Pq21 pin 3 value
                                  Okay 5v is also ok
                                  No problem
                                  Pq21 pin 3 value
                                  Pu9 pin 9 14 18 has 0vs
                                  Pq21 has 15v voltage sir
                                    Pu9 pin 18 is 3v_s5
                                    If it is zero means KBC vcc at 11 pin is missing
                                    Check vcc pin 11 of IT8987 KBC
                                      Check when you press power button
                                      At Pu9 pin 9,18 ,16
                                        Pu9 pin 18 is 3v_s5
                                        pin 11 has 0v
                                        pu9 pin 9 has 0v press goes to 1v then zero
                                        pin 18 0v press goes to 3.3v goes tpo zero again
                                        pin 16 0v press goes 1.7v then zero
                                          KBC pin 11 check with button pressed
                                          Check pu9 pin 14 button pressed
                                          It should not be zero if zero means 3v is not reaching to KBC
                                          Check capacitor c65 both sides and resistor r814
