hp folio 9470m somtimes power on, sometimes not
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hello everyone, I have a interesting problem with HP Elitebook Folio 9470M i5 3rd
    Laptop sometimes power on and works well, but sometimes doesn't power on just power light blinking when I press the power button.
    When laptop works, if I power off unplug the charger and put the charger again laptop button lights just power on 1sec and goes off and doesn't power anymore, Just power light blinking, I need to wait minutes or hour to try again to power on.
    I measure the laptop when working in ID pin I have 3v
    When laptop doesn't power ID pin 0volt, voltage just appeare when i put charger for e second and 0v.
    I try
    3 different charger with more amps
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: hp folio 9470m somtimes power on, sometimes not
    DC Jack and look closely at centre pin of power connector, it should not touch surrounding barrel metal body
    Connection is loose
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      Connection is loose
      Same story
      It's blinking 9-10times
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Power led blinking very fast and contiously?
        Remove CMOS cell , battery and press power button for 30 sec and release and connect adapter only and start
        Measure voltage on charger ic all pins
        All pins ,
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          May be RTCRST issue. ON many HP dc jack light blinks when there is a cap shorted/leaky on rtc section.
          • digitalpc
            • Jun 2016
            • 305
            • .DLL
            pin1 18.9
            pin2 1v
            pin3 0.9v
            pin4 5.9v
            pin5 6v
            pin6 0v
            pin7 0v
            pin8 0.8v
            pin9 0.8v
            pin10 0v
            pin11 3.3v
            pin12 3.3v
            pin13 3.3
            pin14 0.2v
            pin15 2.6v
            pin16 3.3v
            pin17 0v
            pin18 0v
            pin19 0v
            pin20 0v
            Chipset is getting more hot than normal
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              Abnormal condition
              Share schematic and share charging ic number
              Replace power resistor or called CLR
              Voltage not passing through as pin ,2
              If still same
              Replace charger ic
              • digitalpc
                • Jun 2016
                • 305
                • .DLL
                Abnormal condition
                If still same
                Replace charger ic
                I replace both, but same
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Voltage at rtc section as suggested above?
                  Voltage on gate of DC MOSFETs ?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Your readings seems incorrect. How can you have different voltage on pin1 & 2 unless and otherwise R6000 is broken?? PIN5 reading at 6V is also near impossible. There are many such discrepancies. Are you counting the pins correctly??
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • Tend0
                      HP Folio 9470m 6050A2514101-MB-A02.no Main Power
                      by Tend0
                      Hello everyone. I have on the table HP Folio 9470m with mobo 6050A2514101-MB-A02. Laptop has not power. No main power
                      19v present on source of Q6010
                      the gate have 19v
                      the drain have 0v
                      i test these mosfet (Q6009; Q6010) but it like good i think the probleme is Q6009 ADP_EN signal from KBC before replace KBC Controller i come here to find well the faulty compnnenent. Thanks for helping
                      Shematic of mobo
                      03-13-2025, 04:06 PM
                      03-31-2024, 02:12 PM
