HP Folio 9470m 6050A2514101-MB-A02.no Main Power
  • Tend0
    E.E.C.S
    • Oct 2021
    • 92
    • Burkina Faso
    Hello everyone. I have on the table HP Folio 9470m with mobo 6050A2514101-MB-A02. Laptop has not power. No main power
    19v present on source of Q6010
    the gate have 19v
    the drain have 0v
    i test these mosfet (Q6009; Q6010) but it like good i think the probleme is Q6009 ADP_EN signal from KBC before replace KBC Controller i come here to find well the faulty compnnenent. Thanks for helping
    Shematic of mobo
  • mon2
    • 14657
    Before replacing the KBC, confirm that the main power rail is not shorted.
    Remove all power. Meter in resistance mode.
    Test Q6010 is ok with a resistance check of:
    source / drain
    source / gate
    gate / drain
    Each resistance must be hundreds of k ohms or higher if normal.
    Next,
    Measure the resistance to ground of pin # 1 on U6000 (ACN).
    Attach the power adapter (be sure it is suitable to power this board @ 65W or higher).
    Measure the voltage to ground of:
    U6000 charger IC
    REGN pin # 16
    VCC pin # 20
    ACPRES pin # 5
    ACDET pin # 6
    Otherwise, yes, Q6010 is a P-channel mosfet that requires the gate to be a lower voltage than the voltage being passed betwee source / drain pins. For this action, Q6009 must be enabled with a logic high signal on the gate of Q6009. Then Q6009 will conduct and force R6015 to ground which will create a voltage divider to lower the gate voltage on Q6010 to enable.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 92
      • Burkina Faso
      thank for reply
      Test on Q6010 in resistance mod:
      source / drain = 229k
      source / gate = 150k
      gate / drain = 512k
      Measurement of the resistance to ground of pin # 1 on U6000 (ACN) = 50k
      65w power adapter plug mesurement to ground of U6000
      REGN pin # 16 = 5,97V
      VCC pin # 20 = 18,80V
      ACPRES pin # 5 = 3,31V
      ACDET pin # 6 = 2,66V
      • Tend0
        E.E.C.S
        • Oct 2021
        • 92
        • Burkina Faso
        Hello!!! what's next step?
        • mon2
          • 14657
          [QUOTE]source / drain = 229k
          gate / drain = 512k
          [/QUOTE]
          To me, the first 2 posted measurements look low. Suggest to flux and carefully remove this part off the board. Allow it to cool down. Then repeat the same mesurements on the part while it is on your work bench. Are the measurements still in this range? Post the measurements.
          reference:
          https://electronicsbeliever.com/how-...-defective/​
          • Tend0
            E.E.C.S
            • Oct 2021
            • 92
            • Burkina Faso
            Thank for reply ok
            • Tend0
              E.E.C.S
              • Oct 2021
              • 92
              • Burkina Faso
              After remouve Q6010 and let cool motherboard and take mesurement it same
              mesurement take in motherboard:
              source / drain = 231k
              gate / drain = 513k
              After fallowing topic to find defective mosfet, all different test q6010 like good
              • mon2
                • 14657
                Can you confirm the mosfet measurements are from the mosfet on your work bench? (Not on the motherboard)
                If yes, the measurements still look low to me for a good mosfet. A good working mosfet should have very high hundreds of k ohms on each measurement.
                • Tend0
                  E.E.C.S
                  • Oct 2021
                  • 92
                  • Burkina Faso
                  No the mesurement is from motherboar where i remouve mosfet
                  here mosfet mesurement i remouve
                  Calibre 600k
                  source red prob / drain black prob= OL
                  source red prob / gate black prob = OL
                  gate red prob / drain black prob = OL
                  I have this model SI7129DN Mosfet on stock if any doubt i can replace with it
                  • mon2
                    • 14657
                    Then the removed mosfet is not shorted is ok to use on the board. The OL = over limit for the scale used for measurement. This means that the 600k resistance scale is too low. This is good for a mosfet check. If the resistance was still low then the mosfet is leaking and is considered to be defective. The fault of your board is elsewhere.
                    • Tend0
                      E.E.C.S
                      • Oct 2021
                      • 92
                      • Burkina Faso
                      Much apprciate our informative feedback, i'll be explore other part to try to find fault. thanks so much
                        HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                        This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 06:34 AM
                        HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook Specification for Upgrade or Repair
                        This specification for the HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 + USB-C Universal Dock boardview and EliteBook Folio G1 + USB-C Universal Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        09-06-2024, 06:30 AM
                        HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook Specification for Upgrade or Repair
                        This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 Notebook PC (ENERGY STAR) boardview and EliteBook Folio G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-06-2024, 05:30 AM
