MacBook 820-2213-A location of EFI SPI chip
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    My MacBook A1181 EMC 2139 bricked itself
    Had it dual-booting Snow Leopard and MX Linux 19.3
    Did a few Snow Leopard updates, culminating in EFI 1.1 update I think it was
    Followed instructions to shut down from the update screen, then press & hold power button until the light started flashing and a tone sounded
    Then it seemed to start the update OK, although progress bar was increasing at a glacial pace
    So I left it going, and returned to find it booted into MX
    Did a restart from MX, after which nothing - neither startup chime nor anything on the screen
    Tried PRAM reset, also holding down power button again, to no avail - latter makes light start flashing, but then nothing
    And Firmware Restoration CD 1.4 doesn't work - perhaps because the questionable DVD drive can't read a rewriteable CD
    I can't even eject the CD by holding down trackpad button at power on - the MacBook starts without startup chime or anything on screen, and seems not to respond to the keyboard
    So I reckon my only remaining option is rewrite firmware from a 2MB .FD file extracted from the restoration CD's dmg
    But I can't find the EFI chip which I assume is a SOIC8
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: MacBook 820-2213-A location of EFI SPI chip
    U6301
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Merci beaucoup
      Groan - underneath, no wonder I couldn't find it
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • SSBDADC234
        MacBook Pro 14". The screen DP chip failed.
        by SSBDADC234
        When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
        However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
        Testing the chip pins with a multimeter revealed a short circuit inside the chip.
        Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
        04-19-2024, 08:51 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
      • daltonjr.
        Macbook a2338 M1 CD3217 chip compatibility
        by daltonjr.
        I have a2338 MacBook with one bad CD3217 chip. Are there any compatible chips on aliexpress that actually work? Or only chip from same motherboard can be used?
        I remember buying one CD3215 for older 15" model on aliexpress and that one worked.
        Thanks!
        03-03-2025, 05:37 AM
