820-3115 (MBP mid 2012 13") works only after heating up SMC region
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    This MacBook was slightly water damaged, had not a stable PPBUS_G3H due to a broken wire in the battery charging circuitry. (Pin 4 of R7050 to R7052 pin 2)
    After repairing this, the Macbook worked stable for +/-5 days without battery (defective PCB IN the battery, so disconnected for now). This morning after plugging in, nothing again.
    PPBUS_G3H only 2,9V. I forced SMC_RESET_L down. PPBUS_G3H became 12,2V.
    I decided my problem would be around the SMC. I discovered when I heated the SMC slowly with an hairdryer, the computer boots up and keeps working.
    After power down and the SMC region cools down, nothing but a green charger light and too low PPBUS.
    Is this a know issue, or maybe dirt under the SMC chip?
    thanks!
    Gert
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: 820-3115 (MBP mid 2012 13") works only after heating up SMC region
    Usually Capacitors reacts to heating.
    Check U5010 circuity (its nearby SMC) it has to work if you want SMC to start its job . Pin1 and Pin3 is getting Voltage? Also maybe C5020 is shorted? Try to measure ohms to ground on C5020 pin1 (with charger disconected)
    • piernov
      • Jan 2016
      • 4439
      • France
      The SMC itself shouldn't cause PPBUS_G3H to be 2.9V instead of 12.2V/12.6V. The SMC can cause PPBUS_G3H to be 12.2V instead of 12.6V.
      In any case if PPBUS_G3H is stuck at 12.2V (no battery) I'd make sure SMC_RESET_L and PP3V3_S5_SMC_VDDA are always 3.42V, then reball SMC, and replace it if still not working.
      • Beeldbuisje
        • Jul 2020
        • 57
        • Belgium
        SMC_RESET_L and PP3V3_S5_SMC_VDDA are always present.
        PPBUS_G3H is really 2,9V. If I short SMC_RESET_L to ground, G3H rises to 12.2V. (After heating up SMC G3H rises to 12.6V and the MacBook boots)
        I think the circuitry around U5010 doesn’t make sense here, because when I manually resets SMC (R5000 short to ground for a while), I’ve the same behavior as when I plug in the charger.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          If you really heat only smc, then just try to change it, probably fastest way to find out
          • Beeldbuisje
            • Jul 2020
            • 57
            • Belgium
            The PCB extracts a lot of heat. By heating up SMC, everything in 2cm2 becomes warmer.
            I don't have my own reballing machine. So I want to be sure ;-)
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              You dont need reballing machine to reball smc, only stencil, balls and air station. When i want to make only one chip hot, i put thermal pad on that chip and put soldering iron on that thermal pad.
              • tom3k
                Dell Precision 5540. Need clean ME Region
                by tom3k
                Laptop: Dell Precision 5540
                MB: LA-H331P Rev: 1.0(A00)
                Hi.
                I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                After extracting my BIOS in FIT the ME Region size is 7565 KB.
                However the ME Region files I fouud online are 11688 KB in size.
                Can someone help me find he correct clean ME Region?
                Thanks!
                Code:
                ║ Family │ CSE ME ║
                06-28-2025, 12:34 PM
              • Adenitz
                Clean ME region - a bit of theory
                by Adenitz
                Hello laptop repair experts,
                can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
                I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
                What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
                Recently, I had a two cases where laptops (one is Lenovo Idepad...
                10-21-2023, 04:44 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Lexsmash85
                Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                by Lexsmash85
                Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                08-06-2025, 03:41 AM
              • EasyGoing1
                The best way to drive a heating element?
                by EasyGoing1
                I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                This is the general setup that I have now.
                This is what the...
                01-25-2023, 11:29 AM
