Bios XM25QU64 error
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    Bios XM25QU64 error
    XM25QU64
    when i read via rt809f verrification failed, error
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: Bios XM25QU64 error
    first check the contacts.and try to apply a little pressure on the chip while reading.
    • superdota2
      • Jun 2015
      • 64
      • PHILPPINES
      already tried solder to adapter to make sure, but still the same, maybe i need chip.
      • Zibbo
        • Mar 2017
        • 202
        • Zimbabwe
        Have you found any solution? I am experiencing the same problem.
        • mon2
          • Dec 2019
          • 14010
          Is this device supported by your programmer?
          do you have an adapter? This is a 1v8 flash device. Can be damaged if used at 3v3.
          • Zibbo
            • Mar 2017
            • 202
            • Zimbabwe
            Yes I do have an adapter. I used a Winbond 25Q64FWSIG instead and it worked.
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • greg.chalk
              Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
              by greg.chalk
              I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
              Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
              I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
              (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
              10-02-2022, 10:54 PM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              The TV does not turn on, the standby indicator is on. All voltages are present.
              Emms is dead. Not readable, not detected.
              Replaced emmc.
              But with another dump there is no launch
              Terminal log
              UART
              AC_ON
              RPMB key is not yet programmed
              HASH1_VERSION=0x00000000 64bit
              E-B
              FDE enabled
              layout pattern onebin by SAR7,0...
              06-01-2025, 02:11 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
