Bios XM25QU64 error
  • superdota2
    • Jun 2015
    • 64
    • PHILPPINES
    Bios XM25QU64 error
    XM25QU64
    when i read via rt809f verrification failed, error
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: Bios XM25QU64 error
    first check the contacts.and try to apply a little pressure on the chip while reading.
    • superdota2
      • Jun 2015
      • 64
      • PHILPPINES
      already tried solder to adapter to make sure, but still the same, maybe i need chip.
      • Zibbo
        • Mar 2017
        • 204
        • Zimbabwe
        Have you found any solution? I am experiencing the same problem.
        • mon2
          • 14659
          Is this device supported by your programmer?
          do you have an adapter? This is a 1v8 flash device. Can be damaged if used at 3v3.
          • Zibbo
            • Mar 2017
            • 204
            • Zimbabwe
            Yes I do have an adapter. I used a Winbond 25Q64FWSIG instead and it worked.
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
              by Vesko356
              08-11-2023, 03:27 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • greg.chalk
              Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
              by greg.chalk
              I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
              Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
              I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
              (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
              10-02-2022, 10:54 PM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
