HP dag54amb6d0 No Power
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    I have this unit came from other shop, NO light on the charger.
    missing VIN Supply that is used to power up main regulator and other supplies.
    I have checked the charging IC but it is different from the board that I worked before.
    U19
    pin 18 DCIN - 19v
    Pin 1 ACIN - 2.5v
    Pin 2 ACOK - 3.1v
    Pin 20 VDD - 5.2v
    Pin 19 VDD - 5.2v
    Pin 29 ISLCMSRC - 19v
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: HP dag54amb6d0 No Power
    What is voltage on cmsrc line pin 29 and gate of pq50 and pin 30 of ic, also check pq54 for short to ground
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Adding above pin ,6 of ic should be high when ic detects valid adapter, it is a signal to Io that adapter present.
      • ronelex
        • Oct 2016
        • 195
        • Philippines
        This is what I read on those pins
        PQ50 - 25v
        Pin 29 - 19v
        Pin 30 - 25v
        Pin 6 - 0v
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Voltage on ad_id?
          Did you check pq54 ?
          Also check pc357 and pc 5315 capacitors short to ground
          You said main regulator ? Which one
          • ronelex
            • Oct 2016
            • 195
            • Philippines
            ad_id meausures 1.09v
            PQ5is god
            No short
            Idont know how to create the VIN Supply rail
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              check pc357 and pc 5315 capacitors in beep mode
              • ronelex
                • Oct 2016
                • 195
                • Philippines
                No beep at all sir
                it reads 0.600V in diode mode
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Your charging ic is not working properly
                  Replace it, before replacing do check pq53 .
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    looking at the measurement values in your first message, it seems that the PR382 is also a VIN voltage. U5101 bios can be improved with flash program. If u5101 in 8 pin 3.3 v
                    I'm not happy to be so strong. because it's not humanly
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
