Attempting to repair HP 15-f387wm
  • Grey Beard
    • Oct 2020
    HP laptop charger light on, but won't turn on.
    I have checked; charger - Good
    19.6 volt path - Good thru all sub power supplies.
    3.3 volt - Present at IO.
    Tried Mobo in & out with nothing connected but - old then new, power button - Dead.
    Stumped.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Attempting to repair HP 15-f387wm
    Stumped.
    Hi, is this dau99vmb6a0 rev a motherboard?
    Dont listen to the Nay sayerssS
    Last edited by stingerchamp; 10-29-2020, 09:49 AM. Reason: Dont listen to the Nay sayerssS
    • Grey Beard
      • Oct 2020
      Yes, it is the DAU99VMB6A0 Rev-A Mobo.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi ,
        Do the hard reset and check
        1-Push Power button on for the 20 sec while no charger plugin and after wait for 20 sec plugin and try to turn on the laptop .
        2- remove accessories and remove battery and remove RTC battery and wait for 30min and then put it back and try to turn on with power charger plugin alone
        • Grey Beard
          • Oct 2020
          Sorry for the delay. I did as you suggested & still nothing.
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Do you have schematic for this motherboard?
            Does laptop turn on with only battery connected?
            Have you tried CMOS reset by holding
            Win+ v with power button for 2 sec then release power button only but keep holding win+ v until CMOS is invalid option display on your screen. Reset bios
            Do you have schematic so we look for fault using schematic.?
            When you get schematic check AD_id pin voltage
            If you have 90 watt charger it should be around 1.25
            For 45w it is .47 Voltage. For 150 watt it should be around 2.5 , I am not sure for the 150 watt.
            Check power button voltage it should be 3.3 before pressing and 0 after press/holding.
            3 voltage rail is present or not, 5 voltage rail.
            Check Suspend voltage ( not present)or always (present) before .
            Do you have voltage on rtc cell it should be above 2.8 Vol.
            • motormayhem
              Lenovo T460 Only Charges on One Charger
              by motormayhem
              Laptop Question
              I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
              A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
              05-12-2023, 01:46 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
