HP Elitebook 820 G3 - Locating BIOS Chips & Not Powering On
  • cwnt
    • Sep 2020
    • 5
    I got two HP Elitebook 820 G3 laptops sold as "untested/for parts" ages ago and finally got round to testing and attempting to fix them.
    The first was easy enough and after replacing the missing/broken parts runs great, however has a BIOS password the seller does not know. I'm pretty new to this but I've had a read around and it looks like this can easily be removed using the tool by RethoricalCheese here:
    The bit I'm struggling with is actually finding the BIOS chips. I've completely removed the system board to have a look and can't see anything obvious, but then I'm not entirely sure what I'm actually looking for. The HP parts number for the board in them is 831762-001 and it seems to also be called 6050A2725001-MB-A01 in some places. Would anybody be able to let me know where they can be found on these laptops?
    My understanding is that once I've found the chips, they can be read with a SOIC8 clip and CH341A programmer. Once read, I can then run them through the tool above to remove the passwords, and load them back onto the chips. Is this right?
    The second laptop is the exact same model and was missing the same components, however on testing will not even power on. When plugged in, none of the LEDs light up at all and nothing happens when the power button is pressed. I've tried this both with and without a battery and have the same problem. Does anyone know what could be causing this and if it's something that is potentially fixable?
    Thanks for your help and this is my first topic here, so please let me know if I've messed anything up.
  • pokotan
    • Dec 2018
    • 13
    • japan
    Re: HP Elitebook 820 G3 - Locating BIOS Chips & Not Powering On
    Main BIOS chip is here.
    There are 2 types.
    1. Socket Type. (attached images)
    2. Soldered.
    Chip is WSON8 both types. Not SOIC8.
    • cwnt
      • Sep 2020
      • 5
      There are 2 types.
      2. Soldered.
      Thanks, much appreciated! I'm currently at work so can't check, but I don't remember seeing a socket there when I was looking yesterday, so I assume mine are soldered.
      If this is the case, is there any way to read it while it's on the board, or would I have to remove it first? I'd guess I can still use a CH341A programmer but would need a different adaptor instead?
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        You need to des older it and solder it on wson pcb. Never use the clip always desolder the chip. Clip gives errors. That is mine advise
        • cwnt
          • Sep 2020
          • 5
          Thanks for the advice. Just had a check and both of mine are soldered rather than in a socket. I have a PCB they should fit I think.
          Do you think it is a good idea for me to try desoldering if I've never done it before? Or am I likely to damage the chip or board?
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Test it first on scrapboard for soldering skills. If that goes well you can try on your own board. That is my advise.
            Good luck
            • cwnt
              • Sep 2020
              • 5
              Good luck
              Thank you, appreciate the advice. Will give it a go and see if it's worth the risk on the motherboard.
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                ok good luck my friend
                • Wutru
                  HP Elitebook 820 G4 BIOS repair assistance required
                  by Wutru
                  Hi guys,
                  If someone would be able to provide some expertise, I'd be very grateful.
                  BIOS Corruption - Cause
                  So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                  After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                  09-06-2025, 10:32 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Guest
                  Elitebook 850 G5 BIOS bricked
                  by Guest
                  I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                  I assume the BIOS update failed, so I searched for the BIOS chip.
                  I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                  However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                  Can the corrupted...
                  03-24-2025, 01:21 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • lap-top123
                  Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                  by lap-top123
                  HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                  Hp Elitebook 850 G8
                  ProdID 52W98EC#ABD
                  SN# 5CG1458XQ7
                  Mac-address #1: 84:14:4D:2C:4B:5B
                  UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                  Mainboard : 6050A3216701-MB-A01(A1)
                  08-20-2025, 07:28 AM
