lenovo g710 gpu ram problem
  • Anethra
    • Dec 2018
    • 70
    • Turkey
    I have a little question. There iş a laptop with 820m GPU. The graphics are disorted in games. There is no problem with onboard intel graphics. When I run GPU memtest, the test fails. The Ram on the board is H5TC4G63AFR and There are four of them. The problem is I cant provide them. Instead of this Ram model if I use eight H5TQ2G63DFR, Will there be a problem? Or can I use another Ram model? Any help appreciated.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: lenovo g710 gpu ram problem
    The VBIOS must have the profiles for the new VRAM configuration, and you must change the VRAM strapping resistors to select the correct profile. Better put the same VRAM as originally on the board. You can try first to reball the VRAM instead of replacing it if you can't find it. In any case it could be a dead GPU as well.
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • konradx
      Lenovo Thinkpad T15 Touchscreen problem bios
      by konradx
      i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
      That is my DUMP.
      My device:
      SN: PF29Y4N6
      1s20S7S2WF00PF29Y4N6
      MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
      09-06-2024, 01:33 AM
    • madrali
      lenovo e15 gen2 bios ? problem
      by madrali
      Model: Lenovo ThinkPad E15 Gen 2 (Intel)
      20TD-50S0KU00
      Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
      I used Lenovo's SmartBeep decoder and it returned error 0284:
      "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
      I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
      06-16-2025, 12:06 PM
    • Ziome3eknh
      Lenovo x1 carbon problem
      by Ziome3eknh
      Hello, I have a problem with this computer.
      After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
      Will it be a RAM or CPU problem?
      below is the computer details
      Lenovo x1 carbon...
      01-29-2025, 02:35 AM
    • roman728
      Lenovo E15 / NM-C421 Charging Problem
      by roman728
      Hello guys,
      I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
      02-20-2024, 03:40 AM
