Nvidia 740m error code 43
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I does anyone encountered this type of problem I already tried cahngign driver from Latest to odler version of its driver. I also tried changing to windows 7 and windows 10 but same problem.
  • dellxps15
    • Feb 2014
    • 1591
    • italy
    Re: Nvidia 740m error code 43
    ur gpu is dead. u need new bga.
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Hi i got the same problem with my son's laptop with radeon r5 M230 the problem was the windows 10 1909 update. I removed the windows update with advanced options. I run then heaven benchmark and it works flawless. Maybe you can try it. Everytime i do the update i got the same proble so it is definitely the update in my case. Maybe this is helpfull
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Ouch. I hope not.
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Gau_saha
          Bluetooth driver error (code 10)
          by Gau_saha
          Hi
          I am not able to put on bluetooth dongle.Its giving bluetooth error (code 10).
          I have uninstalled the driver and reinstalled it .same problem persist .
          Help needed for troubleshooting the problem .
          12-12-2024, 09:30 AM
        • piernov
          NVidia bumpgate
          by piernov
          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
          May complete this post at a later date with more details.
          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
          03-27-2021, 10:34 AM
        • Maalobs
          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
          by Maalobs
          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
          The relevant service manual for the chassis is available here.
          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
          When I short the SDM to ground I get the layer-2 error code 53.
          The inside of the TV has no damaged components and no swollen capacitors.
          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
          04-02-2019, 01:15 PM
        • totoFR37
          MSI GL75 9 Se Nvidia GPU code 43
          by totoFR37
          Hello guys.
          I own an MSI GL75 (i7)
          Motherboard : 17E51
          GPU : Nvidia 2060 RTX
          I spent weeks to install and clean the drivers but still have an code 43 and the Nvidia GPU not working.
          When using the GPU-z the GPU is recognized but there is no clock frequency.
          Seems the problem is from the hardware.
          What do you advice me to check ?
          06-02-2025, 05:13 AM
