Bluetooth driver error (code 10)
  • Gau_saha
    • Feb 2020
    • 35
    • India
    Hi
    I am not able to put on bluetooth dongle.Its giving bluetooth error (code 10).
    I have uninstalled the driver and reinstalled it .same problem persist .
    Help needed for troubleshooting the problem .
    • 31094
    try adding some usefull info
    bluetooth device,
    driver version,
    operating system version
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
    • bohaboha
      error code 0x80072f8f 20000 When widows upgrade to 10
      by bohaboha
      when upgrading windows 7 to windows 10 i get this error code (title).then to correct the error i have to enable tls 1.1 and tls 1.2 in registry editor. but there I do not find TLS 1.1 and TLS 1.2 instead there is SSL2.0
      in REGISTER EDITOR on windows 7 ad can one do to correct the problem?
      Error Code 0x80072f8f 20000
      08-30-2023, 07:06 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • CdDvdFlash
      Hitachi HTA-DD3W AV Receiver Error Code -Protect-
      by CdDvdFlash
      I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
      07-10-2023, 06:05 AM
