Asus k43u no power
  • String2016
    • Nov 2015
    • 2235
    • philippines
    Asus k43u no power
    I have this Asus k43u PBL50 LA-7321P REV:1A, 19v is present but on power button and on JBTN1 pin 1 ON/OFFBTN# has 17v instead of 3.3v.on the bios chip there is no 3.3 on pin 8, anyone can help on this please
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus k43u no power
    One of the components are faulty PU301 PQ303 PQ304
    • String2016
      • Nov 2015
      • 2235
      • philippines
      I check pq303 pin 1 and pin4 are beeping does this short?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        remove PQ303 out of the bed & test S D G if short replace RT8202 check voltage pin 16 13 17 3 8 14
        • String2016
          • Nov 2015
          • 2235
          • philippines
          @Techtiger thanks for the response, replaced pq303 mosfet now no beeping on the pin1 and pin 4 and here is the measurement of RT chip pu301
          pin 13= 3v
          pin16= 19v
          pin17=5v
          pin14=2v
          pin3=2v
          pin8=3.3v
          • String2016
            • Nov 2015
            • 2235
            • philippines
            On PQ303 no voltage on S and G on drain it has 1.5v fluctuating voltage
            • Techtiger
              • Oct 2014
              • 1602
              • france
              do you get B+ on PL301 19V ?
              • Techtiger
                • Oct 2014
                • 1602
                • france
                pin 13= 3v
                pin16= 19v
                pin17=5v
                pin14=2v
                pin3=2v
                pin8=3.3v
                the voltage on RT is fine what is the voltage on PL305?
                • String2016
                  • Nov 2015
                  • 2235
                  • philippines
                  PL301 have B+ 19v but PL305 both sides 0v
                  • String2016
                    • Nov 2015
                    • 2235
                    • philippines
                    PQ305 pin1 S and pin4 G beeping
                    • String2016
                      • Nov 2015
                      • 2235
                      • philippines
                      replaced PQ305 still same issue PL305 no voltage
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        check resistance to GND on PL303 PL305 left one PAD of each coil & try if the voltage is back if not replace PC305 PC303
                        • String2016
                          • Nov 2015
                          • 2235
                          • philippines
                          PL303 Pullout 1 side= 11omhs PL305 pullout 1side =2.2ohms tried plugged in with 1 side pullout still no voltage on PL303 and Pl305
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            11 & 2.2 Ohms is very less can you check ENTRIP 1/2 it's connected to GND with 133k & 162K Résister make sure no leak & PQ307 pin 2/5 voltage check if PQ307 for any faulty
                            • String2016
                              • Nov 2015
                              • 2235
                              • philippines
                              I check pc305 is shorted beeping when i pulled it out same its beeping pc303 is not shorted, I cannot find same value on this cap on my scrapboard
                              • String2016
                                • Nov 2015
                                • 2235
                                • philippines
                                Problem solved!!! replacd PC305 laptop is now turns on and working fine @techtiger thank you for your help
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. đŸ˜…
                                  05-29-2024, 02:01 PM
                                • ShadowAi
                                  ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                  by ShadowAi
                                  Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                  Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                  After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                  03-15-2024, 10:46 AM
                                • meraklinetx
                                  Asus Z97-a power cycle, no boot no cpu voltage
                                  by meraklinetx
                                  Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                  05-10-2023, 06:08 AM
