How to solve this IP of the lpatop is detected?
	Tags: None
 Re: How to solve this IP of the lpatop is detected?
 looks like computrace or something ? ,can`t see the image is too smallComment
 It could be a fake scam message. Does this message happen at boot ? ,can you get into the bios,does the message only pop up when using the browser .Comment
 its a scam . i tried searching the number but couldn't find a fix . am thinking hdd will need totally wiping and bios / firmware will have to be flashed ...
 will it run live linux from usb or dvd ?Comment
 it's a scam,
 as someone who has extracted and looked at the rootkit known as "computrace" i can tell you it does not post messages to the user.
 if it's in the bios - you will need a utility to examine UEFI modules/appsComment
 i tried reformat the drive but alwasy same and I aready r=trried changing the drive, can I try bios flash??Comment
 I also have the exact same message. However, it has DeviceFreeze-4309 on top-left corner. How to fix it? the laptop BIOS is already unlocked. Is it because of Absolute Persistence Module (computrace) on BIOS? Or really is a scam message?Comment
 HP Elitebook 840 G6
 (840 G6 model) Is this a virus malware? How can I remove this? I searched for the number on Google and it shows that it is not legit (probably a virus). I just bought this laptop last week, and everytime I connect it to the internet, this error pops up. Another thing that I found is Computrace or Absolute Persistence Module but I'm not sure what the problem is. The BIOS was unlocked yesterday, but the problem still persist.Comment
 Re: HP Elitebook 840 G6
 idindt try to flash the EC CHIP(840 G6 model) Is this a virus malware? How can I remove this? I searched for the number on Google and it shows that it is not legit (probably a virus). I just bought this laptop last week, and everytime I connect it to the internet, this error pops up. Another thing that I found is Computrace or Absolute Persistence Module but I'm not sure what the problem is. The BIOS was unlocked yesterday, but the problem still persist.Comment
 I have only seen this kind of message related to computrace, but if that thing still exist after bios reflash and a whole wipe. that could be either a genuine computrace, or a scam. Once activated, the computrace bios element is designed to be un-disableable with bios reflash or user interaction. Comptruce should be visible in the bios when it is equiped with computrace in some sense, other than that I gues it would not be computrace. rpc will be active in the process or services at the same time . Comptruce should be visible in the bios when it is equiped with computrace in some sense, other than that I gues it would not be computrace. rpc will be active in the process or services at the same time .Comment
 Yes Absolute Persistence is set to Active and rpcnetp is running on services. I guess my problem was really computrace but I bypassed the message prompt (devicefreeze) by blocking some adresses in the hosts file but I think its only temporary. Is it possible to disable it?I have only seen this kind of message related to computrace, but if that thing still exist after bios reflash and a whole wipe. that could be either a genuine computrace, or a scam. Once activated, the computrace bios element is designed to be un-disableable with bios reflash or user interaction. Comptruce should be visible in the bios when it is equiped with computrace in some sense, other than that I gues it would not be computrace. rpc will be active in the process or services at the same time . Comptruce should be visible in the bios when it is equiped with computrace in some sense, other than that I gues it would not be computrace. rpc will be active in the process or services at the same time .Comment
			by EvazXHello everyone,
 I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
 Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
 For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
 However, after some time, the replacement motherboard...08-25-2025, 06:09 PM
			by mecha1166About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
			by spacezI have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
 Service Tag: J2MSHW3
 |Express Service Code: 41518077843
 mother board LA-L402P REV 1.0(A00)...-
							Channel: BIOS Requests ONLY!
			by Nikan.eGreetings and Salutations!
 I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
 The faulty DrMOS was removed, and the burned PCB area was milled away.
 All voltages are now good, but the GPU is not being detected.
 I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
 I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
 I thought these pins were used for communication during startup?!?
 On all...03-30-2025, 07:21 AM
			by superdota2HP 15s-FQ2552TU
 da0p5hmb8f1 rev f
 sn# 5CD138CCH4
 problem is power on but no display,no bios post
 i search bios here ,i found and it work and got display.
 https://www.badcaps.net/forum/showthread.php?t=104925
 second problem is nvme drive not detected in bios intel rapid storage,
 i tried a working nvme drive but still not detected in bios,
 also tried install system and install intel rapid driver,still not detected....-
- Loading...
