HP G4 DA0R24MB6G0 totally dead, no leds
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Re: HP G4 DA0R24MB6G0 totally dead, no leds
    I changed PQ37 because it had fail, had 19.3v in all pines, now has 19.3v in pins 4,3 and 26v in pin 1
    PU8
    Pin value
    13 12.04v
    14 2.05v
    20 19.3v
    17 29.3v
    Thank you again
    • Techtiger
      • Oct 2014
      • 1602
      • france
      It’s time to change KBC
      • ruletero
        • Nov 2018
        • 182
        • Mexico
        It's so bad because I don't have kbc programmer but I'm going to find it in my failed motherboards.
        Thank you Techtiger, your help is very appreciated.
        • Mike Russell
          Lenovo 14ALC6 - NMD521 - No power, totally dead.
          by Mike Russell
          Machine won't power on, no power led, no fan spin, completely dead.
          Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
          Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
          VCC 20v
          ACDET 2.8v
          ACDRV 0v (goes to pin 4 gate of AONS32314).
          ACOK 0v
          REGN 6v
          According to datasheet, conditions are correct for ACOK to be high but it is not.
          Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
          12-25-2024, 08:31 AM
        • phantomEVO
          [HELP] 2 Imac 820-2641 TOTALLY DEAD: NO LED/1 LED
          by phantomEVO
          hi to all! please help with 2 imac 21,5 dead...
          i already changed u7700 in both without luck
          u7700 pin 17, 18, 5, 4, 24, 12
          have those voltages in both imac..
          12v, 5v, 5v, 5v, 0,3v, 3,9v
          i have 3V3_S5 (L7710) in one imac (one led) but no 5v on L7750
          NO SHORT ON L7750
          i have not 3V3_S5 (L7710) in the other (no led)
          PLEASE HELP I'M GOING CRAZY!!
          01-25-2024, 01:46 PM
        • phantomEVO
          [help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
          by phantomEVO
          've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
          replaced u5000 with a brand new one now i have
          PPBUS_G3H=8.18
          3V42_G3H=3.42
          3V3_S5 3,3
          no voltage for PP3V3_SUS (no shorts
          on u8020 i have 0v on P3V3SUS_EN no shorts
          0v on R1464 no shorts
          SMC_ADAPTER_EN, 0v
          PM_BATLOW_L, 3,3
          PCH_DSWVRMEN, 0v
          PM_DSW_PWRGD 0,9v​...
          02-26-2024, 10:08 AM
        • bios_
          Gigabyte X570-I dead (no Boot, display, LEDs)
          by bios_
          I have this ITX motherboard from Gigabyte paired with a 3900X and 32GB of RAM,
          The board is only a few months old. I had taken it out of my case (in working condition) a few weeks ago, since I needed the case for something else. The board was left uncovered inside a workshop-type area (yes, bad) for that time and accumulated a little dust. Before trying to use it again I of course cleaned it off with compressed air and make sure that no dust or debris was left on the board.
          Pressing the power button makes the PSU click-on and the CPU fan spin, but nothing more. No...
          11-28-2022, 03:35 AM
        • pixellegolas
          Lenovo yoga 3 pro, totally dead
          by pixellegolas
          Hi!
          I have this laptop and first let's go through what happened
          Went totally dead, no reaction
          I thought it was the adapter so I bought a new one = nothing happened
          Opened up the laptop and adjusted the battery cable = Started working
          Worked a couple of days and then went totally dead again
          Now nothing works
          I have opened the laptop, removed basically all removable components. It does not start without the battery or harddrive or anything disconnected.
          Testing with voltmeter I can see 5.3V basically...
          09-05-2020, 11:16 AM
