2.2_0402_5% means 2R2 - 2.2ohm ?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    Guys quick question.
    Have water spilled board ans schematic says resistor 2.2_0402_5% .
    that means 2R2 = 2.2ohm ?
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Re: 2.2_0402_5% means 2R2 - 2.2ohm ?
    Yes, correct.
    2.2 = resistance value (2R2 or 2.2ohm in this case)
    0402 = smd size
    5% = tolerance
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • JumpyMan
      Aspire One ZA3 Netbook Keyboard ~ Spilled Water
      by JumpyMan
      Hi! I have an old Acer Aspire One Netbook ZA3 model running Windows XP. It's many years old and all that we've ever used it for was to run iTunes for our show sound system. It's always been great for this purpose. Anyway, long story short, I spilled water in the keyboard before a show, couldn't shut it down as we needed it for our music, tipped it upside down, dumped as much water out as possible, shook it, blew on it, etc. and it basically worked fine except for the keyboard. No function at all but the netbook worked fine for many years using a mouse. Lately, the mouse is starting to not function...
      11-20-2022, 03:51 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
