I cannot erase the whole bios chip with AsProgrammer
  • pecrie
    • Nov 2011
    • 182
    So , I have this W25Q32BVSIG chip.It has the BID0166C.F33 bios.
    I'm trying to erase and to flash again with the F65 version.
    But not all data is deleted from the chip.Is there a way to unprotect the chip first ??
  • pecrie
    • Nov 2011
    • 182
    Re: I cannot erase the whole bios chip with AsProgrammer
    Never mind.It seems that the bios chip is not completely empty.
    There is always a bit of data present
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      check if have set proper size of chip. no protect on bioses
      • pecrie
        • Nov 2011
        • 182
        Yes , the size and brand was correct.But to be sure I took a new W25Q32BV.
        This new chip already had some data on it.
        So , I erased the chip - but on some areas there was still some data left.
        Anyway I programmed the chip with the new bin and the laptop is working.
        But I can not get a picture on a attached monitor via VGA ...
        So , the KB can be defective or the graphic chip is not making the connection ??
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          did u try to use standard app for programmer CH341A?
          • pecrie
            • Nov 2011
            • 182
            What do you mean with the standard app ?
            In Win10 the CH341A software will not work.so I have to use AsProgrammer.
            And yes , I did press the unprotect button before I erase the chip.But I never had a warning that the chip was protected .
            Strange ..
            I used the serial driver to install the .INF of the CH341A - the PAR driver to install the .INF gives a fail in Win10.
            In Win7 I always used the PAR driver to install .INF - and it always worked very well ..
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              https://www.badcaps.net/forum/showpo...6&postcount=10
              Become a Badcaps supporter
              Thanks to all supporters.​
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                In Win10 i use the CH341A without problem
                • pecrie
                  • Nov 2011
                  • 182
                  Are you saying that you use the CH341A as a standalone in win10 ?
                  So , without AsProgrammer ?
                  I now use AsProgrammer and then choose CH341A as the hardware (is that not good) ?
                  But I have used the old ver 1.4.x of AsPrgrammer
                  I didn't know there was a ver 2.0.0a14 - Thanks for letting me know
                  Will do another test one of these days ...
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    i use CH341 with its standard software/can download everywhere/ in win10 without problem for years
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Hi there here is beter program netter tegen Standard and as programmer . Will support more and more stable.
                      Regards Steve
                      • pecrie
                        • Nov 2011
                        • 182
                        Stevedb ,
                        Thank you.I will try it ..
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          No problem succes
                          • pecrie
                            • Nov 2011
                            • 182
                            @Stevedb ,
                            So I did use Colibri and I notice that the info that was still on the blanked bios chip - with CH341A and AsProgrammer - was the data in the "status registers" .
                            I deselected the status registers and now I could erase the whole bios chip.
                            So far so good.
                            Then I programmed the chip with the latest and correct bios firmware for this model laptop.
                            And when comparing the chip with the bios firmware - it says that there are 17 diferences.
                            And I see that the status registers are again selected - S16 until S23 - with the code 0xFF
                            Not sure what this all means - but it seems to be part of the firmware or not ?
                            Only AsProgrammr does not show this - I only see that there is still data left on the chip.
                            Anyone knows what these status registers do or what the function is for this data ?
                            • Jeroentje
                              • Dec 2017
                              • 82
                              • Nederland
                              Originally posted by pecrie
                              @Stevedb ,
                              this is a good question, do you already know the answer ?
                              br
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1866
                                @Stevedb ,
                                So far so good.
                                Have you tried doing it this way? This is what worked for me on a Winbond 25Q64FVSIG out of a ASUS X75VD that I had a lot of hell writing the latest BIOS to.
                                1. Save actual contents to a BIN file just in case. I know it's probably useless but I do that in case something does not work, even if it wasn't working before.
                                2. From the menus, select Unprotect
                                3. Erase the chip
                                4. Do a blank check just so you can be perfectly sure it's blank. I had a certain chip (Gigadevice 25Q64, out of a Samsung NP300E5C-A02RO) fill the bar up to 16% and then claim it was done erasing - a blank check revealed the chip was in fact not erased correctly.
                                5. Open your file
                                6. Start writing it to the chip
                                7. Wait until it's done, then test for differences.
                                Main rig:
                                Gigabyte B75M-D3H
                                Core i5-3470 3.60GHz
                                16GB DDR3-1600
                                Samsung SH-224AB DVD-RW
                                Delux MG760 case
                                • Conste
                                  • Oct 2018
                                  • 235
                                  3. Erase the chip
                                  5. Open your file
                                  Do you desolder the EEPROMs?
                                  I have seen similar things, whenever it occurs I desolder the chip and then erasing works fully.
                                  • Dan81
                                    SNES-powered
                                    • Oct 2013
                                    • 1866
                                    I had to do that on the ASUS X75VD I was working on as the clip wouldn't read jack from the board despite me positioning the clip correctly on the chip so it could make contact. I had to use a SOP8 spring socket that was in the package when I bought the programmer but even then, I had issues getting the Winbond W25Q64FVSIG chip to flash until I used Colibri with the above guide I came up with (which was somewhat copied from win-raid - that was the procedure used for AsProgrammer on the forum - since AsProg failed on me (as well as CH341's own software), Colibri managed to perfectly revive my mobo.
                                    Main rig:
                                    Gigabyte B75M-D3H
                                    16GB DDR3-1600
                                    Delux MG760 case
                                    • pecrie
                                      • Nov 2011
                                      • 182
                                      Well , I`m not really sure what caused this , to not work.
                                      Just a bit of explaining.At first I used Win 7 32bit and there didn`t seem to be any problems.
                                      Then , of course , we had to switch to W10.At that point I decided to use the 64bit version.
                                      And that is when I noticed that things did not really work smoothly.The drivers for the CH341A that I had used on Win7 32b , now gave me some trouble on W10 64b.
                                      I downloaded the latest firmware for the CH341A but still not a good work process.I also tried with different programs like Colibri.
                                      The problem I had sometimes , was that the driver would not install.
                                      To make a long story short , I don`t remember if I downloaded another older firmware.Or if I just used firmware that was not the latest.
                                      Anyway , I found a driver for 64bit that would install every time on W10 now.And now I could do a better test of the bios chip.The CH341A would most times autodetect the chip also.
                                      Now I have no problem to check the chips.But I did find that some chips are already 1/2 defective - and that`s why they don`t erase 100%.
                                      When I take a new one , there is no more problem.You can also check and feel if the chip is getting warm.When it is on the CH341A.
                                      This is a sign that it is on it`s way out.
                                      So , the most important thing is that you have the correct driver for the CH341A (especially when you use W10 64b)
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1866
                                        Well, if it helps, mine came with some user-made documentation from the seller (and a pretty good one at that) and the driver link bundled inside worked just fine with Win10 Enterprise LTSC 64bit. If my memory serves me right, it's called CH341PAR.EXE, and the driver installer should read "USB-EPP/I2C... CH341A".
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • testaccgta
                                          Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                                          by testaccgta
                                          Hi, everyone!
                                          I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                                          I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                                          09-01-2024, 08:24 PM
                                        • inck243
                                          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                          by inck243
                                          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                          The BIOS...
                                          07-25-2024, 09:17 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • Haganai.NMWP
                                          GA-AX370-Gaming 5 BIOS chip MX25U12873F doesn't erase properly
                                          by Haganai.NMWP
                                          Hello
                                          I can't properly erase BIOS chip MX25U12873F.
                                          I can read it and write it, but before correct write, it have to been erased, but when I click erase program shows success, but when I try do blank verification I have message "chip disconnected".
                                          I use CH341A programmer with 1.8V adapter and clips.
                                          When I try read or write it takes 3~5 minutes and "run" LED on programmer is blinking. When I try erase, it takes up to 15 seconds, but "run" LED isn't blinking and after that, chip isn't erased correctly.
                                          06-01-2022, 06:43 AM
