Asus FX504GM shorted
  • Kuhanzzi
    • Dec 2019
    • 20
    • Suomi
    I need help troubleshooting this laptop.
    When I got this, seller said it might have water damage.
    It had blown mosfet near charger connector, so there must be short elsewhere what caused this.
    I measured few capacitors, and many of them shows there is short somewhere.
    I cant find any schematic for this motherboard (DABKLIMBAB0 REV: B)
    I also tried lifting another leg of inductors to isolate shorted area.
    What should I do next?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Asus FX504GM shorted
    measure short on main power rail. if ok, measure short on every power rail
    • Kuhanzzi
      • Dec 2019
      • 20
      • Suomi
      I don't have schematics or knowledge to resolve rails.
      Here is photo of measure points where short circuit is present.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        short is only when resistance is under 2ohm. so check again
        measure on big grey coils
        • Kuhanzzi
          • Dec 2019
          • 20
          • Suomi
          I injected low voltage and found that this ic is heating up really fast. I removed it and short disappeared. Any idea what it is? I cannot find anything on google with markings
          5X=5C
          225
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            It is not always the chip test the outputs from the ic for short.
              • 21960
              Richtek 5X =
              Take a look at page 9 "Typical Application Circuit" ,you will need to replace the 2 caps and resistor on the top right of your picture.The cap connected to pin 3 might be ok if resoldered.
              • jaxxwolfe
                • Mar 2022
                • Romania
                Hi, did you solve the problem? I have the same issue and my warranty just expired.
                • gustavind
                  • Aug 2022
                  • 8
                  • Denmark
                  Hi
                  I have the same motherboard- as mentioned above, and it also have a short somewhere. It shorts the moment the psu is connected, activating the auto shutdown in the psu. I have tested the connector and the 4+4 connectorpins on the board, and they are all ok. My question is: Where do I go from here? Knowing that the short occures befor powerup, does that narrow the search down?
                  • mon2
                    • Dec 2019
                    • 14677
                    See attached.
                    Often the 2 x DCin mosfets are the suspects. Usually the 2nd one is found to be defective and has to be replaced but start your investigation.
                    Remove all power. Meter in resistance mode.
                    Check the resistance across the mosfet pins and post your readings:
                    source (1-2-3) & drain (5-6-7-8)
                    source (1-2-3) & gate (4)
                    gate (4) & drain (5-6-7-8)
                    Check each of these mosfets.
                    • gustavind
                      • Aug 2022
                      • 8
                      • Denmark
                      Originally posted by mon2
                      See attached.
                      Thank you very much for youre reply!!
                      The readings are as follows:
                      PQ21
                      source (1-2-3) & drain (5-6-7-8) - 0 Ohm
                      source (1-2-3) & gate (4) - 0 Ohm
                      gate (4) & drain (5-6-7-8) - 59 Ohm
                      PQ22
                      source (1-2-3) & drain (5-6-7-8) 75,3 kOhm
                      source (1-2-3) & gate (4) - 59 Ohm
                      gate (4) & drain (5-6-7-8) - 75 kOhm
                      I hope it makes sens..?
                      • mon2
                        • Dec 2019
                        • 14677
                        Both mosfets are with low resistance readings.
                        Can you confirm the meter scale used for each check ? If possible, post a pic of your meter.
                        Is it possible that the meter was showing 'OL' = over limit so the next higher scale on your resistance setting should be selected.
                        • gustavind
                          • Aug 2022
                          • 8
                          • Denmark
                          The meter I'm using sets the scale automatic. The readings on PQ21 are all very low, but the readings on PQ22 are:
                          75300 Ohm
                          59 Ohm
                          75300 Ohm
                          I really appreciate your help :-)
                          • mon2
                            • Dec 2019
                            • 14677
                            The readings are very low. It is very possible that one mosfet is causing the other to look bad. Bad influence from the same family of mosfets. Movie to follow soon...
                            If you wish to proceed and have the tools, remove the 2nd mosfet @ PQ22.
                            Then check the resistance values again. Just note which part is placed where and also the orientation of pin # 1 - a picture will be very helpful before you start.
                            A good idea to also check the resistance of the part after it is removed and on your work table. This will offer a good idea if the low resistance is being influenced by other parts on the logic board or not.
                            Start with remove PQ22 and if required, remove PQ21. These mosfets are very common and can be replaced with other vendors and parts with the same fit and function. Interested in the resistance readings of the pads on the circuit board.
                            Before you proceed, use flux if available, low air pressure so the other parts do not go flying + tweezers + circular motion till the solder melts. Do not force the movement of the parts else the PCB traces / pads will tear off!!
                            Be patient and the mosfet will eventually just swim on the solder pads of the PCB which can then allow you to remove with tweezers.
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              PQ21 is clearly the one that's shorted. And there'll most likely be a short to ground on main power rail.
                              https://www.badcaps.net/forum/showthread.php?t=90356
                              • gustavind
                                • Aug 2022
                                • 8
                                • Denmark
                                Thank you both very much for incredible helpfull pointers.
                                I'll return to the workbench sometime during the weekend, and update as appropriate.
                                Have a great weekend both of you!!
                                • gustavind
                                  • Aug 2022
                                  • 8
                                  • Denmark
                                  Hello again - a short update as of now...
                                  First - I better correct the info on the resistance on PQ21...
                                  PQ21
                                  source (1-2-3) & gate (4) - 59 Ohm !!
                                  ... I'm sorry, my first reading was faulty - I don't know why..?
                                  When that is said - I'm more confident now, that you are both right - One or both of PQ21 and PQ22 has shorted. After reading the excellent thread - https://www.badcaps.net/forum/showthread.php?t=90356 it seems I should also check the main power rail. I can't inject power as of now, as I'm waiting on my bench power supply (wuptidooo :-) ) being delivered hopefully late next week. I have tried to make some readings on the resistance between VA+ and ground and found:
                                  I'm not sure it tells a lot, but ...?
                                  So - I'll wait for my bench PSU, and use the time (after hours) training using the hot-air solder machine on some scrap PB (print boards) I have...
                                  I'll keep you posted...
                                  • mon2
                                    • Dec 2019
                                    • 14677
                                    With enough flux on the part, remove PQ22 mosfet. Be patient to allow for the metal underside pads to melt the solder. Nudge the part now and then to check if the part is able to swim on the surface before plucking it off the board.
                                    Never push this step. The solder will melt if you apply small circles over the topside of this body.
                                    After the part is removed -> check the resistance to ground again for the main power rail.
                                    It should certainly not be a 0 ohm resistance to ground which is concerning.
                                    Is your meter auto-range or you select the resistance scale ? Post more details.
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      Why would you remove the good MOSFET not the bad one?
                                      DC-in MOSFETs have no connection to ground, they won't be responsible for a short to ground on the main power rail.
                                      • mon2
                                        • Dec 2019
                                        • 14677
                                        Only to rule out suspected parts.
                                        • OOF DIO
                                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                          by OOF DIO
                                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                          (Had 3 problems, now just 1)
                                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                          04-19-2025, 05:03 PM
                                          ASUS TUF Gaming FX504GM-E4056T Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GM-E4056T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GM-E4056T boardview and FX504GM-E4056T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 12:00 PM
                                          ASUS TUF Gaming FX504GM-EN479 Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GM-EN479 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GM-EN479 boardview and FX504GM-EN479 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 09:17 AM
                                          ASUS TUF Gaming FX504GM-E4387 Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GM-E4387 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GM-E4387 boardview and FX504GM-E4387 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          ASUS TUF Gaming FX504GM-EN003 Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GM-EN003 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GM-EN003 boardview and FX504GM-EN003 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:30 AM
