Apple 820-2523-B green light, no fan spin
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello .
    Have this Apple 820-2523-B that have green light on chager , but have no fan spin.
    I measure that i have good voltage on PBUS, PP3V42_G3H, PP3V42_G3H, PP3V3_S5, PP1V2R1V05_S5
    system takes 0.6W and whe i press powerbutton it goes down to 0.4 and after while back to 0.6W
    i even reballed the MCP ic but no change
    anybody have idea where to check for fault?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Apple 820-2523-B green light, no fan spin
    History? Check all power rails before and after pressing power button.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      damn. found straight short on GPU resistor withou gpu coil
      • piernov
        • Jan 2016
        • 4439
        • France
        Which one, what resistance to ground?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          R8940 without resistor 0,1ohm on GPU side
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            anybody knows if there can be made DIS to UMA?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              strange thing is when i inject 1V it take max 1A so it is not short
              • piernov
                • Jan 2016
                • 4439
                • France
                Was the GPU reflowed?
                It may be possible to bypass GMUX like on 820-2915. In any case you can first remove the GPU inductors or current sense resistors to see if the machine turns on (even with no display/no POST).
                • jheunne
                  a1278 820-2936a fan spin green light only help
                  by jheunne
                  hi there i have a macbook pro a1278 board 820-2936a no boot no dispaly only fan spin and green light. i seen some corroision on top starting to u4900 to u3890 i manage to clean it but still no luck to boot. i figure out that in pp15v t29 there is no available out voltage it shows only 0.6 volts only...
                  10-24-2024, 04:19 AM
                • xalapamac
                  Macbook air 820 - 00165 fan spin, PPVCC_S0_CPU present, No green Light, No Chime
                  by xalapamac
                  Hello, greetings everyone. I NEED YOUR HELP
                  I got this macbook that doesn't turn on, I don´t have a green light, but it's got a fan spin for a few minutes and after it's off.
                  This macbook comes in without damage from liquid spill.
                  The story of the Mac is that the screen closes and left without use for two days. Then they try to turn on and it won't turn on. Then they connect the charger and it doesn't give light.
                  It´s a Macbook Air 2017
                  Please help me understand how this works... Correct me if I'm wrong in my way of...
                  01-09-2021, 12:31 AM
                • MOSSEP
                  Monitor Audio RSW12 - Green light, but no sound
                  by MOSSEP
                  Hi
                  Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                  Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                  The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                  I have already tried replacing all of the...
                  01-26-2025, 08:33 AM
                • MOSSEP
                  Monitor Audio RSW12 - Green light but no audio
                  by MOSSEP
                  Hi
                  01-26-2025, 08:18 AM
                • lcdcaps1
                  820-2610-A Sys onewire help, no green light. Please help from the gurus
                  by lcdcaps1
                  Hi
                  I have an 820-2610-A motherboard that has no green light.
                  I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                  From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                  The sys onewire circuit on this model and others is more involved
                  I was hoping if anyone knows about this and how it works, can reply and let me know
                  I know this is an old model but I am sure there are people who still works on these or knows about them
                  I get 1.1v on the C7771 capacitor and will replace...
                  11-06-2023, 01:28 PM
