ASUS X442U With Power but No Display, 2 of the Power Supplies are not Switching
  • Techbuddy2020
    • Aug 2020
    • 14
    • Philippines
    I don't have a schematic and board view so I take pictures to the power supplies that are not switching.
    Unit is with power but no Display.
    Main power rail = 19V
    Main Bios Pin8 = 3.3V
    Power button = 3.3V
    No Voltage in RAM= I suppose that supply I label #2 with Voltage In 19V - No Drain Voltage
    Label #1 (see image) - with Voltage In 19V - No Drain Voltage
    Already checked all the mosfet but its not shorted It seems that they are not switching at all. I think the Driver of those mosfets are Faulty can anyone confirmed. Your input here would be a great help! Thank you!
  • Techbuddy2020
    • Aug 2020
    • 14
    • Philippines
    Re: ASUS X442U With Power but No Display, 2 of the Power Supplies are not Switching
    I also wanted to inject supply to see what is heating up but I do not know where to inject and how much voltage needed.
    • Techbuddy2020
      • Aug 2020
      • 14
      • Philippines
      I check again the laptop and found out that there are 3 more supply that are not Switching so Total of 5 supply that are not working.
      Charging Light always On even without battery.
      Steady Power LED Light after pressing power button.
      Only 19V found in the LCD/LED Connector no other voltage
      Could it be the SIO Chip is Faulty?
      SIO- ene KB9026Q C
      Please anyone could give me an idea. What would be the possible issue on this laptop. Thank you! Stay safe!
      • Techbuddy2020
        • Aug 2020
        • 14
        • Philippines
        Any input would highly be appreciated! Thank you!
        • Techbuddy2020
          • Aug 2020
          • 14
          • Philippines
          Hi, Update: I checked the Resistance to Ground on coils please see the actual value on the image. Those circle in yellow are not working. Can anyone tell me if the resistance value are good. Thanks and stay safe!
          • Techtiger
            • Oct 2014
            • 1601
            • france
            S4(SUSP# SUSON#) S3 State (RUN ON) are missing that’s why no voltage on the coils Resistance is good find out requirements off SIO chip find out the data sheet of SIO ,may be Bad Bios Flash BIOS with a good Bin back up old bin
            • Techbuddy2020
              • Aug 2020
              • 14
              • Philippines
              Originally posted by techtiger
              S4(SUSP# SUSON#) S3 State (RUN ON) are missing that's why no voltage on the coils Resistance is good find out requirements off SIO chip find out the data sheet of SIO ,may be Bad Bios Flash BIOS with a good Bin back up old bin
              @techtiger
              Already flash the BIOS still the same. Could you please check the data of the SIO in the image versus the Actual Voltage value? Thank you for the input highly appreciated.
              • Techtiger
                • Oct 2014
                • 1601
                • france
                check the voltage on the pins 37 84 89 before you press PWRBTW & after press the PWRBTW
                  • 20766
                  boardview - https://www.badcaps.net/forum/showthread.php?t=85968
                  • Techbuddy2020
                    • Aug 2020
                    • 14
                    • Philippines
                    Those Pins has 0v before and after press the PWRBTW.
                    • Techbuddy2020
                      • Aug 2020
                      • 14
                      • Philippines
                      Originally posted by SMDFlea
                      @SMDFlea
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        now you have the Bordview from @SMDFlea test if the SIO get the power are you sure no voltage on those pins ? pin 22 96 125 116
                        • Techbuddy2020
                          • Aug 2020
                          • 14
                          • Philippines
                          Yes, I am sure. About this pins 22 96 125 116 also 0V before and after.
                          • Techbuddy2020
                            • Aug 2020
                            • 14
                            • Philippines
                            Does it mean that the SIO is Faulty?
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              SIO is not getting power that's why all OV you have to trace it back to 3/5V Regulator with help of the Bordview trace it back, You should have some basic knowledge when you are troubleshooting check PU8701 all inputs & out puts
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Check RTCRST as well.
                                • Techbuddy2020
                                  • Aug 2020
                                  • 14
                                  • Philippines
                                  @techtiger
                                  You might be right this may be the issue. I checked the voltage out few times and some of the pins changed its voltage value (eg. Pin8 & 9) It has voltage at first and after I pulled off the charger and plug it again the voltage becomes 0V. Same thing with Pin 3 & 4 and few other pins.
                                  • Techbuddy2020
                                    • Aug 2020
                                    • 14
                                    • Philippines
                                    @mcplslg123
                                    I can't find the RTCRST and I don't see an RTC Batt on this board.
                                      by sam_sam_sam
                                      07-01-2024, 06:34 AM
                                    • ShadowAi
                                      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                      by ShadowAi
                                      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                      03-15-2024, 10:46 AM
                                    • meraklinetx
                                      Asus Z97-a power cycle, no boot no cpu voltage
                                      by meraklinetx
                                      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                      05-10-2023, 06:08 AM
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
