Asus G750JZ R2.0 just need one resistor value
  • Dr.xyz
    • 11
    • Finland
    No picture on LCD panel, resistor between DDC power pin (pin 22 on display conn) and +3VS is open circuit. Probably caused by bad display cable, now replaced.
    Value of resistor? It might be just 0 ohm, but just wanted to make sure.
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: Asus G750JZ R2.0 just need one resistor value
    Value of resistor? It might be just 0 ohm, but just wanted to make sure. Anyone have this schema?
    try this schematics if its the same. ..https://www.badcaps.net/forum/attach...9&d=1507792334
    • Dr.xyz
      • 11
      • Finland
      No, it's not the same. DDC power comes straight from +3VS on that board, no resistor in between.
        • 20873
        Rev 2.0 boardview - https://www.badcaps.net/forum/showthread.php?p=982113
        • Dr.xyz
          • 11
          • Finland
          Thank you, Sir!
          It was indeed zero ohms, that's what I used already. After replacing, got picture with lots of static.
          U6201 eDP to LVDS bridge chip was also damaged, took that from a donor board and after replacement picture was OK.
          Previous shop also damaged display and HDD connectors, need to swap those too.
          • schematic_jack
            ASUS TUF B450-PLUS II motherboard schematics, or does this 60B SMD resistor even matter?
            by schematic_jack
            I think it would be dumb to toss a "modern" motherboard just because a resistor got scraped off, so here I am. I am hoping to find the right schematic so I can see if the motherboard can live without 1 of 3 60B SMDs in series likely scratched off by the backplate of a PCI-E card install or removal. It could be related to a functionality that is not needed or critical, or it could fry anything I plug into it and power on. If I could find a replacement, I could likely pop in on the board, but if I don't need to, then screw it, I don't mind leaving something dark that doesn't matter....
            07-06-2025, 02:00 PM
          • dutchgaucho
            Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
            by dutchgaucho
            Hi colleagues,
            Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
            Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
            On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
            11-09-2023, 11:27 AM
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
            09-07-2024, 02:50 AM
            ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
            This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
