Acer E5-411 No Power
  • mygemsga2019
    • Aug 2020
    • 21
    • Philippines
    Hi, Anyone could please help me fix the issue of Acer E5-411
    It's not coming On. But voltage in power switch is present 3.3V. No short on the main power rail. 5V and 3v are present. My main concern is the BIOS Voltage which is 0.8V only and I think not enough. Bios Voltage is coming directly from the SIO Chip.
    I suppose that even the Bios is Low on Voltage the laptop will turn On though you can see nothing on the screen if I am correct. But the laptop is totally dead even after switching On.
    I need advice from experienced Tech here if I need to replace the SIO chip. Or if You have any input that can fix the issue would highly be appreciated. Stay safe everyone!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer E5-411 No Power
    What is the voltage on pin8 of main bios?? Is that also 0.8V?? Thats your +3VPCU line-so you need to probe why its getting pulled down. Platform quanta ZQM??
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      the bios has the program to initiate boot sequence so if you dont have power to the bios ic.. its like you computer is in off state though you press the power switch you get nothing try to focus there no bios ic voltage.. if you have the schematics trace it there.. check the power rail.. the ALW voltage 3.3 , 5v, 1.8 etc..
      Never stop LEARNING because life never stops TEACHING!
      • mygemsga2019
        • Aug 2020
        • 21
        • Philippines
        @mcplslg123 Yes Voltage on pin8 main BIOS is also 0.8V. And yes Platform quanta ZQM.
        • mygemsga2019
          • Aug 2020
          • 21
          • Philippines
          @Duranitron The Main BIOS VIN is coming from SIO Chip Pin88 which is also 0.8V does that mean that the SIO CHIP is faulty? Please need clarification on this. I like your slogan though. That is the true meaning of Life.
          • mygemsga2019
            • Aug 2020
            • 21
            • Philippines
            UPDATE: I measure again the pin88 in U7(SIO CHIP) to PQ1(Pin3) the reading is 1.8V and I think its normal. After passing to PQ1(Pin1) the voltage is dropping to 0.8V. Any idea why the voltage is dropping. Need advise please, Thank you!
            One more thing can I inject Voltage to PQ1(Pin1) to see what is getting hot. I am worried if I do so more parts will get burned. Need advise please.
            • mygemsga2019
              • Aug 2020
              • 21
              • Philippines
              Any input need here please! Thank you!
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Are you getting voltage on pin2 of PQ1?? Without proper voltage at pin2, PQ1 will not pass voltage to pin1. Measure voltage on all pins of PQ1 & PQ2. What is the resistance on PIN1 of PQ1??
                • mygemsga2019
                  • Aug 2020
                  • 21
                  • Philippines
                  @mcplslg123
                  PQ1 Pin1 = 0.8V
                  PQ1 Pin2 = 0.0V
                  PQ1 Pin3 = 1.8V
                  PQ2 Pin1 = 0.0V
                  PQ2 Pin2 = 0.0V
                  PQ2 Pin3 = 3.0V
                  Resistance PQ1 Pin = 2K ohms
                  It is possible that the PU1 is faulty?
                  PU1
                  Pin1= 2.5 v
                  Pin20 = 19v
                  All other pins are 0V
                  PQ28
                  Pin3 = 0V
                  Pin3 = 0V
                  Pin3 = 2.8V
                  PQ3
                  Pin3 = 0V
                  Pin3 = 0V
                  Pin3 = 3V
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Try replacing PU1.
                    • mygemsga2019
                      • Aug 2020
                      • 21
                      • Philippines
                      Try replacing PU1.
                      @mcplslg123
                      I replaced the PU1
                      Here's the voltage value each pin
                      1. 2 v
                      2.
                      3. 2.3v
                      4. 2.3v
                      5. 3.4v
                      6. 3.4v
                      7. 0v
                      8. 0v
                      9. 0v
                      10. 0v
                      11. 0v
                      12. 0v
                      13. 12v
                      14. 0v
                      15. 0v
                      16. 0v
                      17. 26v
                      18. 19v
                      19. 0v
                      20. 19v
                      The unit has now power but the issue is once the RAM were installed the unit were shutoff rightaway. so I have done a little more digging and found out that R405 is shorted I want to replace that resistor but I do not know the exact value. cannot be found in the schematic nor in board view. How would I know the exact value of the resistor?
                      R405 Pin1 & Pin2 resistance value = 135ohms
                      Please need some guidance. Thank you so much and stay safe!
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I dont know which schematic you are following but as per the schematic i've for quanta ZQM, R405 is on page6 of schematic and its 0 Ohms.
                        Btw, Does the mb turns on without ram and shuts off instantly with ram??
                        • mygemsga2019
                          • Aug 2020
                          • 21
                          • Philippines
                          Yes, The MB will turn on without RAM and shut off instantly with RAM were installed.
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3590
                            • slovakia
                            so check RAM power rail for short or if comming on
                            • mygemsga2019
                              • Aug 2020
                              • 21
                              • Philippines
                              Yes, I checked PQ26, PQ27, PL9 and PC191 are all good. Capacitors and Resistors around the PU12 are all good. I thought that PU12 is faulty but I'm not sure.
                              The RAM is working I tried it in other laptop.
                              • mygemsga2019
                                • Aug 2020
                                • 21
                                • Philippines
                                Anyone can confirm if PU12 need to be replace. Thank you!
                                • Dumah Brazorf
                                  • Jun 2013
                                  • 179
                                  • Italy
                                  Is the cmos battery good? Have you reset the cmos?
                                  • mygemsga2019
                                    • Aug 2020
                                    • 21
                                    • Philippines
                                    Yes, I replace it with a new bat. Reset the CMOS and still the same.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      You get 1.35V on PL9 without ram?? The voltage is stable?? HWPG_1.35V present??
                                      • mygemsga2019
                                        • Aug 2020
                                        • 21
                                        • Philippines
                                        Everything is good now after flashing the BIOS. @mcplslg123 Thanks for the help you're a good man
                                        Thread Closed
