32MB flash programmer recomendation
  • Needpass
    • Oct 2019
    • 7
    We have an HP Zbook with a 32MB flash chip that needs to be reprogrammed. What is the easiest/best programmer to use?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Re: 32MB flash programmer recomendation
    cheapest
    https://www.aliexpress.com/item/3270...archweb201603_
    will do the work
    • Bonzas
      • 472
      • Indonesia
      if you looking only for bios chip u can use ch341 or ezp20xx series. Both of them cheap. Better buy 1,8v adapter too
      • blair_aaaaa
        • london
        i have tvp2588u. do support 32mb files flashing bios?
        • what_1282105
          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
          by what_1282105
          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
          02-14-2025, 07:27 PM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • imtmiissa
          Dell n5050 Can i flash bios without programmer?
          by imtmiissa
          Dell n5050 after update bios and restarted laptop it hang on black screen
          10-16-2023, 05:28 PM
        • nordlicht
          ThinkPad X1 Nano (20UN) bricked
          by nordlicht
          Hi guys,
          while trying to mod my ThinkPad X1 Nano (model 20UN) I got too impatient to hold the wires pressed to the SPI Flash contacts, so I soldered wires to it, but wasn't paying attention when connecting my programmer and, stupidly, swapped VCC and GND. Thus I fried the main SPI Flash, and I only have an incomplete/corrupt dump (u49_incomplete.bin). The secondary SPI flash on the board (W25Q256JVEIQ) seems to hold two redundant copies of the EC firmware (at 0x1000 and 0xc0000) as well as a redundant BIOS copy. I am fairly confident that the secondary Flash dump is correct (dumped...
          04-27-2022, 12:46 PM
