Dell n5050 Can i flash bios without programmer?
  • imtmiissa
    • Feb 2023
    • Jordan
    Dell n5050 after update bios and restarted laptop it hang on black screen
  • YOUCEF4787
    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
    by YOUCEF4787
    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
    Initial Problem:
    The laptop was completely dead, no signs of life, no power LED.
    Action Taken:
    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
    Current Situation & The Main Issue:
    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
    09-21-2025, 12:19 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Mark01
    Dell Optiplex 7490 AIO - red power led after flash
    by Mark01
    Hi guys,
    This is my first post! 🚀
    I have no idea what I’m doing, but I’m learning by trial and error.
    I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
    07-04-2025, 12:54 PM
  • what_1282105
    Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
    by what_1282105
    Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
    02-14-2025, 07:27 PM
  • zlr8r
    looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
    by zlr8r
    looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
    cheers
    Dell Inspiron 17 (7786) Laptop
    Service Tag: 5J0NHT2
    Bios: 1.9.0
    MOBO: RO 15 17 WHL 2GB MB / 18706-2
    Attached;
    1. My saved bios using a programmer
    2. Dells Bios updater .exe (v1.16)
    3. Dells Bios recovery file
    4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
    5. Image of ME...
    12-18-2023, 03:08 PM
