Macbook Air 2010 11" CPU 0 panic
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    I'm working on a 2010 Macbook Air 11" and it's starting to cost more than it's worth. First issue was the power adapter, then the battery. Sorted those and it worked fine but even though I was connected to wifi, safari did not load any pages. Investigating the connection issues I realized system preferences would not load. This suggest OS issues to me. The computer booted well every time until I tried to reinstall OSX. Then I got a power off by holding down power key.... message. I removed the bootable USB and the system restarted. I then proceeded to backup user data and do a clean install. iPhotos did not load to access the pictures so I restarted then I got a CPU 0 error message, kernel cpu mis-match.....
    No corrosion or visible damage on the logic board
    820-2796 board.
    Really need some assistance, thanks.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Air 2010 11" CPU 0 panic
    Tried booting from external drive with good macOS installed, internal SSD disconnected?
    • MicroSMD Lab
      • Sep 2018
      • 145
      Thanks for the suggestion piernov. I have not prepared an external drive with a Mac OS yet, I guess now is a good time to do it. Will try it and report back.
      • sofles
        Macbook Pro 16" A2141 screen artefacts, kernel panic
        by sofles
        Hi there.
        I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
        I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
        Now situation looks like this, If...
        02-05-2025, 05:05 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
        Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
        Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
        10-22-2024, 02:37 AM
      • prw07
        MacBook Pro A2141 - macOS Kernel Panic
        by prw07
        Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
        How to localize the problem ?
        12-05-2023, 06:57 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
