Dell Latitude E5440 Power Issue
  • dspok
    • Jan 2014
    • 553
    • Nepal
    I have above said model with power issue. Power LED turns on for 5sec and off, battery LED blinking for 1sec continuously after power LED turns off. No power on B+ but all SCL SDA are 3.3v on battery connector.
    3v, 5v is ok but I'm getting 13v on +PWR_SRC. I have changed charger IC no effect. No shorting and No leakage found. BIOS reprogramming may not help in this case in my opinion.
    Can anybody help?
    Thanks in advance.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell Latitude E5440 Power Issue
    anybody?
    • khaahk
      • Dec 2013
      • 759
      • Estonia
      Battery led blinking - is the battery connected or not?
      Why do you rule out bios?
      13V on PWR_SRC should be ok.
      Which power rails come on when power button pressed?
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        Can anybody help?
        Thanks in advance.
        check these power table .. check the alw voltages.. those voltages must be present in order for it to turn on
        Never stop LEARNING because life never stops TEACHING!
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          that 13V is way low. it is ok for stepdown circuits but not for logic.
          check why u have 13V. i have this problem when have one of first two mosfets blown but everything works. blown mosfet have bigger resistance wich pulls 19V down and mosfet was heating
          and remove battery until u solve that low voltage
          • piernov
            • Jan 2016
            • 4435
            • France
            +PWR_SRC is battery charging rail (before current sensing resistor). 13V sounds ok there.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3577
              • slovakia
              looks like, but it is main power rail for every stepdown circuit when u check schematic.
              that charging circuit looks weird
