Replace for isl95835 (No VAGX)
  • david.ercoli
    • Mar 2019
    • 5
    • argentina
    Hello team:
    I have a Toshiba satellite l745-sp4202a (motherboard: date5mb16a0 rev: A).
    It does not have CPU_VAXG. I suspect of the buck converter IC, named isl95835 , but I only have a isl95836 as replace.
    Do you know if I can replace the isl95835 for a isl95836.
    Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Replace for isl95835 (No VAGX)
    Not replaceable between them.
      ISL95836 Laptop PWM Controller Datasheet
      The ISL95836 Pulse Width Modulation (PWM) controller IC
      provides a complete solution for IMVP-7/VR12 compliant
      microprocessor and graphic processor core power supplies. It
      provides the control and protection for two Voltage Regulators
      (VRs). The first VR, typical for Vcore, incorporates 2 integrated
      drivers and can operate in 3-, 2- or 1-phase configurations. The
      second VR, typical for graphics, incorporates 1 integrated
      driver and can operate in 2- or 1-phase configurations. The two
      VRs share...
      11-05-2024, 03:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
    • RetroComputingGrotto
      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
      by RetroComputingGrotto
      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
      What is your advice/opinion on whether or not on old(er)...
      04-03-2024, 08:30 AM
    • chth96
      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
      by chth96
      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
      Since then, This AC/DC adaptor have been out of order.
      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
      And Is there any possibility that it will suddenly explode as well as to be out...
      12-03-2023, 04:40 AM
    • psyduck
      Conformal coating on Samsung U32D970 monitor PSU, do I need to replace after repair?
      by psyduck
      I have a Samsung U32D970 monitor from 2015 I pulled out of the bad hardware pile that turned on and then turned itself back off after a few minutes of use and refused to turn back on. The PSU has part number BN44-00786A, and I found a couple posts about one that had blown with damage to the MOSFETs and PWM controller - but nothing about intermittent failures. I started a new thread and said that I would refresh the solder joints on the board to see if it was just a bad connection and possibly replace the PWM and PFC ICs. I then asked what my next course of action would be after those steps. I...
      11-27-2023, 06:56 PM
