HP EliteBook 840 G2 5v pwm regulator issue.
  • Francisco.s
    • 686
    • Spain
    Can someone identify 5v pwm regulator, (VRP5V0A) from attached photo?
    The motherboard is an Inventec CHICLET 6050A2637901-MB-A02 (UMA)
    It has some minor?? changes/differences seeing the schematic.
    The schematic says that 5 volts regulator is the well known TPS51225, but on the motherboard 5 and 3 volts regulators are two independent chips. ( not a TPS51225 dual pwm regulator)
    Problem with this mobo is that 5 volts are present only for 3 seconds an then goes to zero.
    3.3 volts are present all the time.
    Please help, I can't find any datasheet for chip U6150.
    Thanks in advance.
  • khaahk
    • Dec 2013
    • 760
    • Estonia
    Re: HP EliteBook 840 G2 5v pwm regulator issue.
    Most times it is useful to put the top marking of the chip to aliexpress search box.
    It should be NB676A:
    https://www.monolithicpower.com/en/d...ument_id/6389/
    • Francisco.s
      • 686
      • Spain
      Hi khaahk, thanls for your help.
      I did the search in ebay but not in aliexpress.
      Next time I will change search engine to aliexpress, it is way more better.
      • khaahk
        • Dec 2013
        • 760
        • Estonia
        I have the same board on the table, it has RT7291B instead installed. So they should be direct replacement, "4m=" is the top marking. Just in case for future reference.
        • Francisco.s
          • 686
          • Spain
          The problem is solved.
          EN_5V and EN_3V were always present, but VRP5V0A (5v alw) at coil L6150 only were present for 2 or 3 seconds due to a bad capacitor in this rail.
          A bit difficult to find this capacitor, there are no names for capacitor and resistors, and schematic is also wrong.
          I have to use the schematic of two inventec models to follow the circuit.
          Sometimes Inventec CYCLONED or Inventec Comet matched the circuit better than Inventec Chiclet. (the last is the one it mounts)
          Thanks for your help.
          • reformatt
            • Feb 2020
            • 1404
            Same board came in today which was pretty much dead. This board had reportedly died after the customer plugged in a external HDD via USB with an incorrect power supply. Heard a pop and laptop died.
            The schematics here differ in this model, as the pointed out above, the 3.3V/5V supplies are discrete on the Chiclet version (correspond to U6100 and U6150). U6100 is 3B= --> RT7290A, U6150 is 4M= --> RT7291A.
            The 3.3V LDO voltage was present on pin 6 of U6100, however this was not present at the MEC EC (U300). Scratched my head a while on this one as the schematic from the Comet version indicates that this connects via Pad6103. This does not exist in the Chiclet version. Checked the 5V LDO on U6150 and that was missing. The IC was indeed stuffed, and when replaced, the 3.3V for the MEC appeared. So there must be some logic in the board that only supplies the power to the EC once both 3.3V and 5V LDO's are present. I think these drive the enables for the 3.3V/5V supplies which in turn feed the EC etc.
            The USB board (6050A2638201-USB-A01) was also faulty with a 12 ohm short from +5V to ground on one of the ports. With this plugged in, the fan just ran at full speed and it wouldn't switch on. There isn't much on that board, and when I pulled off U2511 (I think) that disappeared. Markiong on the IC is 2540 CC, I think it is a TPS2540 but it appears that a STCC2540 is equivalent. I had a spare board that I used though but datasheet seems to line up with whats on the board.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3582
              • slovakia
              why dont u inject? u dont need schematic for this kind of repair
              • chbalnuweit
                HP Elitebook G5 (COMPUTRO-6050A2945601) Power Throttling Issue
                by chbalnuweit
                i am facing a strange problem with an HP Elitebook 840 G5. Unfortunatley no board schematics are to be found on this one (COMPUTRO-6050A2945601)
                The laptop runs at 0.4 GHz and is always in BD PROCHOT protection. Even in the BIOS it shows 400MHz CPU clock... And same issue when booting a Live Linux. So I am pretty sure I can rule out problems with the OS. It must be lower level.
                I've been researching this behavior the past 2 days and tried EVERYTHING I could find on that topic.
                What I noticed playing around is that when I disable...
                11-08-2023, 01:18 PM
              • Dev Goose
                Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                by Dev Goose
                Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                What Happened
                The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                12-13-2024, 03:13 AM
                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-07-2024, 05:50 AM
