HP Pavilion dv5-1160ev
  • olorin
    • Sep 2013
    • 82
    • Greece
    Hello.
    I have an HP Pavilion dv5-1160ev. I opened it for cleaning. All good until It opens normally in the BIOS, but it does not boot either disk or dvd or external media ... I saw a black screen after bios ... What's going on?I change cmos battery, load bios primary defaults. Thanks!
  • servis_null
    • Oct 2014
    • 82
    • Croatia
    Re: HP Pavilion dv5-1160ev
    Originally posted by olorin
    Hello.
    If you loaded BIOS defaults, I would check boot order or SATA mode: IDE / AHCI / Compatible first
    • olorin
      • Sep 2013
      • 82
      • Greece
      Hi.My laptop does not have this option.
      • olorin
        • Sep 2013
        • 82
        • Greece
        Any answer?
        • lapfix
          • Mar 2020
          • 2741
          • my workshop
          See if it's a pb of boot mode : legacy or UEFI .
          • olorin
            • Sep 2013
            • 82
            • Greece
            does not have such an option...
            • olorin
              • Sep 2013
              • 82
              • Greece
              please help
              • krawat274
                • Jun 2020
                • 53
                • Poland
                Hello. Can you describe situation more specific? Before cleaning all was allright? Laptop booted from HDD? Is HDD visible in BIOS? Can you upload photo of your BIOS settings?
                • olorin
                  • Sep 2013
                  • 82
                  • Greece
                  Before cleaning all was perfect.
                  Hdd is visible in bios.
                  • krawat274
                    • Jun 2020
                    • 53
                    • Poland
                    Try to power on laptop and press F9 or F12 to go inside boot menu. Then, select Hard Drive as boot source and press enter. If you can't get inside boot menu, try to change boot order in BIOS (first place as Hard Drvie, second CD/DVD etc.).
                    • olorin
                      • Sep 2013
                      • 82
                      • Greece
                      I try this but nothing happened
                      • Shrimp_Green
                        • Sep 2018
                        • 8
                        • Brasil
                        Hello, greeting from Brazil.
                        The black screen is the memory test. This happens when the system does not boot from Hard Disk.
                        Try putting the HD as First Boot:
                        Enter Setup:
                        System Configuration>
                        Boot options>
                        Boot Order>
                        Leave the HD as first.
                        • olorin
                          • Sep 2013
                          • 82
                          • Greece
                          See video who shows the problem.
                          https://gofile.io/d/R66Dem...
                          This happen with any boot device ,like hdd,cd or flash drive
                          • krawat274
                            • Jun 2020
                            • 53
                            • Poland
                            Which OS is on your HDD? Maybe MBR has been corrupted. Try this:
                            https://www.partitionwizard.com/part...s-mbr-fix.html
                            If this solution doesn't help, try to reprogramm BIOS.
                            • olorin
                              • Sep 2013
                              • 82
                              • Greece
                              Originally posted by Shrimp_Green
                              Ola, saudação do Brasil.
                              Enter Setup:
                              Boot options>
                              Boot Order>
                              I've done it.
                              no change
                              • olorin
                                • Sep 2013
                                • 82
                                • Greece
                                Which OS is on your HDD? Maybe MBR has been corrupted. Try this solution:
                                Is windows 7...I think hdd no have problem because before cleaning work's perfect...Now laptop appears black screen from any boot device like hdd ,dvd,usb flash drive,external dvd....
                                I try to found BIOS for this laptop but hp didn't have it in her site....
                                • krawat274
                                  • Jun 2020
                                  • 53
                                  • Poland
                                  Post your old dump here:
                                  https://www.badcaps.net/forum/forumdisplay.php?f=40
                                  Maybe someone will be able to upload proper dump for you.
                                  • Bloodhoundje
                                    HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                    by Bloodhoundje
                                    I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                    I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                    After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                    I have desoldered the bios chip (GigaDevice...
                                    03-16-2024, 03:12 PM
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
