ideapad 320-14iap dg424/dg524 NM-B301 auto shutdown
  • p7comuter
    • Mar 2015
    • 68
    • Philippines
    need help,auto shut down/power off after windows is loading..if you try to clean format it also shutdown at menu..i think this is board problem...anyone ecountered this kind of problem? if you are in bios setup menu it will not shutdown/power off
    n
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: ideapad 320-14iap dg424/dg524 NM-B301 auto shutdown
    n
    sayo b yan or parepair lang..bago mangyari yan ano naging symptoms..
    try to see if the cpu fan is spinning ..do you smell something or heating inside maybe the gpu is overheating or memory problem.. does it heat up before it shutdown. try to boot to dos and try to run dos based memory tester test the memry and see if turns off?
    Never stop LEARNING because life never stops TEACHING!
    • p7comuter
      • Mar 2015
      • 68
      • Philippines
      bro auto shutdown even cold start pa lng. There are no overheat parts on the board. He is similar to the problem of toshiba nec tokin. Dos mode or bios mode doesn't pop off. When he loads windows, he powers off. When it reopens, it will reopen again. So it is not over heating problem.
      Bios reprograming try ko tommorow. Have you encountered this problem bro in lenovo 300 series?
      Wlang cpu fan yun this model bro and already try other ram like that.
        • 20709
        Post in english please so other members can understand .
        • p7comuter
          • Mar 2015
          • 68
          • Philippines
          Ok sorry bro. I think this is vcc core related problem. Everytime windows load it will shut-off. Same as toshiba nec tokin problem. Do you encounter this kind problem in lenovo ideapad?
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            try to update bios...i have encounter this kind of problem with acer laptop..in loading windows it freezes i only replaced the n mosfet that powers the processor..leaky ..
            • p7comuter
              • Mar 2015
              • 68
              • Philippines
              ok bro i will try
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                In windows it shuts down-after how many minutes??Did you tried flashing bios with clean me region?? Thermal paste is good??
                • p7comuter
                  • Mar 2015
                  • 68
                  • Philippines
                  unit will shut off after that stage of booting i attach the photos,,lenovo logo and loading circle after that,the system will shutdown..already try to replace n-channel mosfet at cpu core still the same problem..do you is it bios related problem?
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    try to monitor all the voltage ALW the processor voltage the memory voltage the bios ic voltage.. when powering up.. one of this must be the problem.. what is the resistance of the processor voltage pin to ground?
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      possible of gpu problem ..
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        look for shorted capacitor beside and bottom of the processor area
                        • p7comuter
                          • Mar 2015
                          • 68
                          • Philippines
                          Thanks for the tips kabayan. I did not solved the problem, client already taken his unit. I tried Bios flash( no effect pa din) ,yes i think also its processor/gpu problem na.
                          • kalilinux25
                            DG424/DG524 NM-B301 Rev 1.0 no display and power issue
                            by kalilinux25
                            Hi good day this unit has a display at first and after flashing the bios chip got broken the original one is W25q64fwsiq and changed with W25q64fwsiG
                            no idea if they are compatible after flashing unit wont power if pressed lightly, but if you tried long press it will power but no display , So I tried all bios in the forum same issue.
                            I take the board out , its taking 80miliamp and cpu is gettign hot but power led is not turning on
                            Unit is
                            DG424/DG524 NM-B301 REV 1.0
                            2017-03-09
                            SR2Z6 Intel Celeron N3450
                            03-08-2023, 01:12 AM
                          • cruiser_
                            A1466 820-00165 intermittent shutdown
                            by cruiser_
                            hi there,
                            Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                            Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                            Gives shutdown cause -128.
                            Seem to work fine in SMC bypass.
                            Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                            Observations:
                            - SMC_RESET_L - when pulled down - plug goes orange/green and...
                            10-11-2022, 12:06 PM
                          • howardc64
                            P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
                            by howardc64
                            History
                            - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
                            - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
                            - Fixed 2 circa 2015 Vizios before with classical main board...
                            11-28-2020, 04:25 PM
                          • RATIM SIDDIQUE
                            hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
                            by RATIM SIDDIQUE
                            automatic shutdown after 30 sec of display coming
                            do not shutdown without ramstick
                            someone give me idea plz
                            08-20-2024, 03:50 AM
                          • ronelex
                            Acer MS2304 Shutdown when HDD or ODD Present
                            by ronelex
                            Model: Acer MS2304
                            Board Code: 09920-2
                            Issue: Unit Powers On with Display Without HDD or ODD attached
                            When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
                            Unit wont shutdown when ODD or hdd attach if no ram is attach also
                            I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
                            05-15-2021, 01:28 AM
