ideapad 320-14iap dg424/dg524 NM-B301 auto shutdown
  • p7comuter
    • Mar 2015
    • 75
    • Philippines
    need help,auto shut down/power off after windows is loading..if you try to clean format it also shutdown at menu..i think this is board problem...anyone ecountered this kind of problem? if you are in bios setup menu it will not shutdown/power off
    n
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: ideapad 320-14iap dg424/dg524 NM-B301 auto shutdown
    n
    sayo b yan or parepair lang..bago mangyari yan ano naging symptoms..
    try to see if the cpu fan is spinning ..do you smell something or heating inside maybe the gpu is overheating or memory problem.. does it heat up before it shutdown. try to boot to dos and try to run dos based memory tester test the memry and see if turns off?
    Never stop LEARNING because life never stops TEACHING!
    • p7comuter
      • Mar 2015
      • 75
      • Philippines
      bro auto shutdown even cold start pa lng. There are no overheat parts on the board. He is similar to the problem of toshiba nec tokin. Dos mode or bios mode doesn't pop off. When he loads windows, he powers off. When it reopens, it will reopen again. So it is not over heating problem.
      Bios reprograming try ko tommorow. Have you encountered this problem bro in lenovo 300 series?
      Wlang cpu fan yun this model bro and already try other ram like that.
        • 21955
        Post in english please so other members can understand .
        • p7comuter
          • Mar 2015
          • 75
          • Philippines
          Ok sorry bro. I think this is vcc core related problem. Everytime windows load it will shut-off. Same as toshiba nec tokin problem. Do you encounter this kind problem in lenovo ideapad?
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            try to update bios...i have encounter this kind of problem with acer laptop..in loading windows it freezes i only replaced the n mosfet that powers the processor..leaky ..
            • p7comuter
              • Mar 2015
              • 75
              • Philippines
              ok bro i will try
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                In windows it shuts down-after how many minutes??Did you tried flashing bios with clean me region?? Thermal paste is good??
                • p7comuter
                  • Mar 2015
                  • 75
                  • Philippines
                  unit will shut off after that stage of booting i attach the photos,,lenovo logo and loading circle after that,the system will shutdown..already try to replace n-channel mosfet at cpu core still the same problem..do you is it bios related problem?
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    try to monitor all the voltage ALW the processor voltage the memory voltage the bios ic voltage.. when powering up.. one of this must be the problem.. what is the resistance of the processor voltage pin to ground?
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      possible of gpu problem ..
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        look for shorted capacitor beside and bottom of the processor area
                        • p7comuter
                          • Mar 2015
                          • 75
                          • Philippines
                          Thanks for the tips kabayan. I did not solved the problem, client already taken his unit. I tried Bios flash( no effect pa din) ,yes i think also its processor/gpu problem na.
