Compaq Presario CQ61 - Fan spins, no display
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Hello, I have this laptop and it turns on, fan spinning but I have no display or backlight on the screen. I connected it to an external monitor through HDMI but no display. Removed one Ram, reseated the other and swapped them, nothing changed. Motherboard is DA00P8MB6D1 REV: D
    Can anyone help me repair it?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Compaq Presario CQ61 - Fan spins, no display
    disconnect all power remove CPU RAM BIOS battery hold the power button for 10sec & try , dose the key Bord LED flash if so how many times or any beeps ? check the voltage of all BIG Gray Coils & update ?
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      check dc adapter for proper voltage.. check bios ic voltage and also the rtc cmos battery.
      Never stop LEARNING because life never stops TEACHING!
      • WhiteWolfHellas
        • Jun 2019
        • 95
        • Greece
        Did that but nothing changed. I have attached an image of the motherboard with the voltages.
        • WhiteWolfHellas
          • Jun 2019
          • 95
          • Greece
          RTC battery = 3.1V
          Power adapter = 18.3V
          • diif
            • Feb 2014
            • 6978
            • England
            I maintain a fleet of 8 CQ61s of various configurations for a client.
            I've reflowed or replaced the Radeon IGP on more than one to fix an intermittent/no graphics issue.
            • Techtiger
              • Oct 2014
              • 1602
              • france
              can you confirm PL10 PL5 voltage are missing ?
              • Duranitron
                • Jul 2014
                • 544
                • Philippines
                look for something that over heats..specially on the processor or gpu area then measure the gpu or processor voltage and post it here..
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Athlon II version? Probably the motherboard or CPU failed. Look for one of the LEDs on the keyboard flashing like once per 5 seconds. Probably board reporting a CPU comm failure. Possibly bad SMD caps. (maybe the power brick)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • krawat274
                    • Jun 2020
                    • 53
                    • Poland
                    Hello. Try to reprogram BIOS with clear ME region.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      The one I received to reinstall Windows on, was the Athlon II version and it had Windows 7, IIRC. In April, 2013 and it was BSOD'ing at stock clocks. Very strange, as it should be throttling or shutting off instead of a Windows error!
                      Then it looked like I received the same one again in November, 2014, it was dead, with the motherboard apparently flashing a code for CPU comm failure!
                      Arc A770 16 GB
                      • piernov
                        • Jan 2016
                        • 4436
                        • France
                        I bet on yet another dead RS880M.
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          do we solve the problem of op WhiteWolfHellas or this is another case..?
                          • WhiteWolfHellas
                            • Jun 2019
                            • 95
                            • Greece
                            can you confirm pl10 pl5 voltage are missing ?
                            pl10 = 1v
                            pl5 = 0.5v
                            • WhiteWolfHellas
                              • Jun 2019
                              • 95
                              • Greece
                              The PL7, PL8, PL9, PQ39, PQ40, PQ42, PQ43 are really hot but PQ36 and PQ37 (SOP-8) are too hot to touch. Can't even touch it for more than 2 seconds.
                              I have voltages on the CPU area 1.8V.
                              In the GPU area I have 1.8V, 1V. I didn't have the time to check in detail.
                              • WhiteWolfHellas
                                • Jun 2019
                                • 95
                                • Greece
                                There are no LEDs flashing
                                • WhiteWolfHellas
                                  • Jun 2019
                                  • 95
                                  • Greece
                                  I can reprogram the BIOS, but what is "clear ME region"?
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    "ME" is management engine.
                                    That's the Intel portion that interfaces the processor with the motherboard, at least partially.
                                    That's only on Intel.
                                    Arc A770 16 GB
                                    • mielta
                                      • Apr 2015
                                      • 368
                                      Hi
                                      To 99% it is GPU Problem
                                      Do a mild Reflow on them and check if picture come
                                      • Duranitron
                                        • Jul 2014
                                        • 544
                                        • Philippines
                                        if nothing works.. try the suggestion of mielta.. reflow the gpu.. make sure you use solder flux. if nothing happens.. you need a new gpu...
