hp dv6- 6121ee no power + charging led ok HELP
  • doctormasry
    • Dec 2019
    • 98
    • giza
    Mb id : HPMH-41-AB6200-E00G
    NO POWER BUT WHEN I PUT ADOPTER THE LED IS OK WHAITE LED
    PRESS POWER = 3.3V PUT WHEN I PRESS NO POWER
    CHANGE BIOS EC AND MAIN BUT NO NEW
    PL806 = 3.3 # PL804 = 0V BUT AFTER PRESS POWER = 5V
    DB_PWRBTN# = 3.3 ON SW6 AND U19 AND CONNETED
    SB_PWRBTN# IS 0V AFTER PRESS POWER BECOME 3.3V
    RSMRST# ON U19 PIN 97 IS 3.3 V
    PL8011 = 1.1 V ---- PL812 0V AFTER PRESS POWER 1.5V
    ANY IDEA PLEASE HELP
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: hp dv6- 6121ee no power + charging led ok HELP
    first check +V3.3A_RTC RTC_RST# after check RSMRST# should go 3.3 to 0V when press PWBTN depends on the platform & LD05 LDO3 ?
    • doctormasry
      • Dec 2019
      • 98
      • giza
      rtc =3.3 v
      rtc_rst = ok
      rsmrst is ok
      any another idea
      • doctormasry
        • Dec 2019
        • 98
        • giza
        rsmrst on R121 is 0v after press pwbtn = 3.3
        rsmrst on u19 ITE pin 96 is 0v before press PWBTN . after press = 3.3v
        RTC_RST# on D806 = 3.3
        any another idea
        • Techtiger
          • Oct 2014
          • 1602
          • france
          now find out 15V_ALW / ADP_ID / EC_RST#
          RUN_ON / 3.3VSTBY_PCH_EN / SUS_ON /SLP_S4# SLP_S3# when press PWBTN ,
          • doctormasry
            • Dec 2019
            • 98
            • giza
            thanks @techtiger i will check
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • rob_hen
              Dell XPS 13 9370 Laptop, No power, not charging
              by rob_hen
              Hello!
              This is my first post for help, and I am quite newer to board repair, so bear with me.
              I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
              After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
              There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
              My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
              05-01-2025, 09:20 PM
              Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
              by sam_sam_sam
              I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
              https://www.ebay.com/itm/116497313155?var=416785404161
              Here are some of the description from the eBay seller
              The main parameters:
              1. Product name: High-power non-isolated DC boost module power supply.
              2. Product model: 100A2000W.
              3. Input voltage: DC12V-60V.
              4. Input current: 100A (maximum)....
              05-18-2025, 09:45 AM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
